105
there are evap lines that run above the fuel tank I think. Given the codes and the rust in the rear, I'd be concerned about doing too much work to the tank and afterwards discovering it needs to be dropped and perhaps replaced. Of course, there's the chance dropping it now for inspection that everything up there looks good and the work was a waste of effort. I dunno what you can see under the access panels under the seat. maybe a 'smoke test' would be worth paying for?
Emergencey: Stolen Legacy Seattle!
1 Lucky Texan replied to Ratty2Austin's topic in Meet n' Greet. Your USMB Welcome Center
shame to lose your ride like that , I hope it comes back OK. good luck -
the only problem with that log is, there's no distinction made among type/severity of HG failure. it could be better with some 'checkboxes' for things like "did the car overheat?" and "did the car have combustion gasses bubble thru the coolant", "did the car strand you on the road", etc. Some folks only have some dripping and no driveability problems.
only because I read the forums a lot, I'd say you might expect external 'weeping' of coolant. probably reduced by the use of the Subaru conditioner. Some folks seem to develop external oil leaks too. there are also those that feel the older that year range of cars is getting, some more severe HG issues are cropping up - but it may be no worse than other makes of cars. It certainly seems they are more reliable than the 2.5s from the late 90s. People always report problems but don't always make a lot of noise about a trouble-free car ownership experience. even knowing that your neighbor was careful about maintenance, it may be worthwhile to pay for a pre-purchase inspection by a soob-experienced mechanic. If for no other reason than to spot something like worn struts or questionable hoses, etc.
98 may have a separate Engine Temp Sensor - it might be bad, failing to 'choke' the car when cold. Later soobs have that combined with the Temp Gauge Sender. Either way, could be bad. someone will chime in with details for a 98 i'm sure. I suppose one slim possibility would be leak-down of fuel pressure after the car sits for a long period. To test that, next time you're confident the car would fail to start well, cycle the key to ON (but not start) wait 5 seconds, then to OFF. repeat 4-5 times. The fuel pump should cycle on fro a few seconds each time - pumping-up the pressure if it's low. The see if the car starts normally. If it does, maybe an injector is leaking or there's some other fuel pressure issue.
Frankenmotor dyno results
1 Lucky Texan replied to presslab's topic in NA Fuel Injection Engine Tech
torque seems very flat! my WRX is 'peaky' feeling and I don't like that. -
I know you already replaced the diff bushings, but, I've read that there are 'helper' pieces and maybe full aftermarket poly units that go in there. maybe Whiteline or prothane, etc. Also, I believe cardoc over on the outback forum used 3M windo-weld to create some bushings. just mentioning in case someone else reads the thread with diff bushing problems.
