105
dealership is charging $529 It's a lot of money, but probably fair. I would need 150-$200 of tools from harbor Freight to DIY it. Throw in that is before the 90-$100 parts w'ever. And I might screw it up - yeah, I'll let them do it. On the plus side, they said my 06 doesn't have the same problem with the turbo banjo bolt screen as the previous years. Downside, they found a small split on the inner DS axle boot. I might try re-booting it myself, but those boot bands, ugh, what kinda tool tightens/secures those thing? RockAuto sells a raybestos boot kit for about $10;
glad it worked but, over half of WD-40 is 'stoddard solvent' (you can think of it as a sorta deodorized kerosene) and I dunno how it could affect binders in pad material. seems risky maybe pads with different technology would help? if the pads on there now are semi-metallic, maybe switching to ceramic (like Centric posiQuiet Ceramic) or even para-aramid (StopTech Street performance) would stop the rust-welding problem.
did anyone look under the hood? Possible bad alternator. I somewhat suspect the serpentine accessory belt's idler or tensioner pulleys, or the tensioner. the previous issue sounds a little like an evap tank vent problem - or the 'venturi/siphon pump' gadget in the tank getting clogged. Ever have a 'WHOOSH' of vacuum or pressure when removing the gas cap?
got mine from Amazon IIRC. Probably available locally but I was buying other stuff at the time. The bottle is probably a lifetime supply for me. There's a brush built into the lid. decent reviews and one guy seems to feel it will protect well in winter; http://www.amazon.com/Permatex-24125-Ceramic-Extreme-Lubricant/dp/B0018PSASU/ref=cm_cr_pr_product_top again, dunno personally how it would stand up in snow States. But 2 or 3 gurus at nasioc seem to like it. along with nipper's comment, no grease is gonna make up for rust. emery cloth/scotchbrite the surface of the pins or new slider pins might be required once a little corrosion 'bites' into the metal.
that's an excellent price. here's my write up on the process;http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/48910-lower-control-arm-rear-bushing-transverse-link-replaced-prothane-03-outback.html bottom line, unless you're doing it for motorsports reason, try to stay with OEM or you will have increased harshness/'shock' from the Prothane. dunno about any other aftermarket replacement.
I'm not happy, but I made an appointment with the dealership to get the bearing and a coupla other things done. I was assured they will use OEM parts and this way, i get a warranty and hopefully an experienced person on the job. Tools to do this myself would have cost 1.5 or more labor hours. And I might only use them onec or twice. I didn't check if they can be rented/borrowed. Plus, it's unknown territory for me. At least they will give me loaner car and will probably do in hours what would take me 2 days lol! wish I had tha HBA deal in this car.
