105
^^^ good point. It's always a problem for marketing/data-collection folks. Self-selection. It isn't always a true snapshot of reality. You don't get info from folks who don't 'select' themselves to participate. It is also a problem with perception and expectations. If someone's previous car was a Fiat, the Subaru may seem stellar (no pun intended) but, if they are coming from a Lexus, they may be disappointed. Subarus, in some respects, are also like Jeeps in that, they often get used in a manner that exposes them to more risk of damage and severe situations.
I assume you tried more than one CD? The only other thing I can suggest is wacky and even if it works, likely shrt term. TRy putting some pressure on the circuit board with, maybe a piece od rubber eraser or lump of plastic. Try between mount points along each edge, then maybe near the center somewhere....if there's a cracked trace or solder joint, you may get lucky and close it up.
High angle CV boots
1 Lucky Texan replied to Ionstorm66's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have read that proper 'clocking' (timing) of the joints at each end in relation to each other is important to maintain max angle capability. there are some special axles - HIRO ??? - or similar that claim to have more extension , maybe more deflection? but, I don't think they enjoy a great reputation. built like these; https://www.amazon.com/Monster-Axles-Polaris-Sportsman-Scrambler/dp/B07QM254C8 -
I can't recall all the grounds but certainly, with an engine swap, it would be easy to miss 1 or 2 so, double check the straps to the intake mani, the grounds on the dogbone at the firewall area, the strut tower, I think the frame under the radiator? Also wondering if a bad wire in the body to hatch gaiter could cause some weird ness?
well, Not sure my radiator has any specific ground wire. And yes, theory is not the same as practicality. But moving fluids do create friction and that can lead to static charge. Maybe measure from the battery or chassis ground, and a probe touching only the coolant. Maybe try with engine off, vs running at operating temps? Still, there are multiple formulations nowadays for coolants as well so, yeah - could be 'lost in the weeds' time.
headlights? yeah,no ballasts. Some are designed to be rotated for best cut-off line then locked-down with an allen screw or ??? Others may require some creativity on the back side for heatsink or fan clearance. Turn signals may require a load resister or replacement flasher unit. Other installations are polarized I think. it is HIDs that need ballasts.
yeah, not close enough that they are gonna be making the 'time to pull the plug Doc' type decision when I'm dying, but those relatives didn't need/want the car. Still, best alternative at the moment. Really helps them out more than I thought due to coincidence of hail storm.Still, it may get destroyed by a teen driver......
ABS is often the most sensitive system to low voltage on the older cars.... On 3 occasions, on 2 vehicles, I have had a bad battery set 'spurious' codes. But, on older cars, it isn't much of a light show. set the CEL and disabled cruise on my WRX. But new battery, and codes didn't come back. I THINK on the Outback, it was a bad cell in the batt once.
- 7 replies
- warning lights
- at oil temp
(and 4 more)
Tagged with:
Today I prepped the Outback to gift it to a relative. Wife just got a 2021 Honda CR-V and doesn't want to keep 3 cars. At least I found a relative who wants it (actually, during las t night's storm, BOTH his other cars have broken glass and other major hail damage so, kinda works out) . I really wanted to keep it, and it makes the most sense to keep really, but I think I would miss my WRX more. Couldn't bear to trade it in and have it go to an auction house. If I couldn't find a friend/relative who wanted it, I would have listed it on the Forums next. Who knows, it could possibly come back to me someday....
doesn't seem like coincidence, but just in case, make sure brake fluid is not low in reservoir on top of MC.
- 7 replies
- warning lights
- at oil temp
(and 4 more)
Tagged with:
