105
how cold is it in summer where you are? I kinda don't see how ambient temps have much to do with this. Those heat shields are partly to prevent hot exhaust parts from setting fire to grass if the car is parked off-pavement. Also to shield nearby stuff like oil filters, wires, cables w'ever. if an exhaust leak is acting like a venturi and sucking in cold air, fix the leak? I dunno
try a search - I think it's called the oil filter adapter and folks have had to re-seal it. maybe yours is like this? ;http://opposedforces.com/parts/legacy/us_b12/type_38/lubrication_system/oil_cooler_engine/illustration_1/ not uncommon, I suppose there are other possibilities. Are you sure it's oil and not old power steering fluid?
Help! Intake Upgrade, 01 Legacy
1 Lucky Texan replied to WRX's topic in NA Fuel Injection Engine Tech
dig around here for some dimensions/info http://www.greddy.com/products/airinx/airinx-parts/ -
if you need and can determine there's a way to use them, I have the stock springs off my 06 WRX wagon. less than 1900 miles on them. $50 plus shipping. What everyone said about KYB struts is right on. Check RockAuto and even Amazon for prices. And , at the age of your car, you may need to refresh the strut mounts at the top and inspect/replace some bushings underneath the car, inspect ball joints too. Good time to inspect the axle boots too, lots of labor overlaps for several related parts.
does it show the same side? If so, what about swapping sides with front sensors? also, does the scanner you're using have freezeframe data? fuel trims are also broken down by banks (IIRC) and if one bank's trims are are a lot different, could point to a bad plug or injector if the sensors aren't the problm. sorry, all I have is speculation to offer. But converters are expensive and more experienced folks than me all say the converters are sturdy so, it's worth saving that as a last ditch approach.
It isn't common, but perfectly possible to jump a tooth or 2 and still run, poorly. And of course, it would be expected to throw codes as well. But, not necessary to pull heads yet - just the timing covers. As to what you do first - it's a dice toss but, if the tensioner is weak or the belt old and stretched, the possibility of a catastrophic failure is hanging over your head. If you do sensors, plugs, wires etc. They will go to waste if the belt slips/breaks during a test drive of that work.
winner!
maybe re-work the inside of those old gear-hub reducers from the 70s to reverse direction at the wheel? problem is, probably not a good ratio for driving on the road.
probably need to pick up a new axle nut. Hope that's all there is wrong, but you probably need to have a back-up plan, The axle probably has some type of warranty. personally, I've had zero problems with the EMPI axle I put on the wife's car. $10-$15 more than a rebuilt - but new. supposedly, dealerships have rebuilds that are QCed/cherry picked to a higher standard. MWE has soob rebuilds and is highly respected. If it becomes really confusing what the source of the vibration is - try swapping axles left-to-right.
one other thing, did you torque the axle nut with the weight of the car on the tire? It's recommended to torque the axle with the hub in the air. back-up the rotor with a big screwdriver in the 'vanes' and against the caliper. but many people have complained about vibration from rebuilt axles as GG mentioned.
P0743
1 Lucky Texan replied to ocei77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
did the d'stick's tube get bent during the swap? this seems very odd. -
Lol...
1 Lucky Texan replied to TheSubaruJunkie's topic in BRZ and its Sister the Scion FRS/Toyota GT86
I think there are no Lexus in Japan, that line was created for US marketing reasons. Maybe Infiniti too? I've often thought Subaru should do something similar - break out the 'Legacy' plate as a separate, 'upscale' line(Tribeca, Outbacks - and maybe a 'luxury' Forester and BRZ?) as a sorta Lexus-type maneuver. Run the name 'Subaru' for the Crosstrek, WRX/STI, maybe a downscale Forester and the other Imprezas. Then, bring over the R1s or design some FWD/Electric/maybe hybrid subcompacts and name them 'Fuji' (to compete with the Scion - type line of vehicles). the reason, so I've read, that the Lexus line was created, was so folks didn't feel 'cheated' paying 35K for "a little Toyota". Japanese cars had the reputation of being small and cheap. Nobody wants to feel they paid Rolex money for a Timex watch. There could have been a vehicle brought over from Japan or Europe with Toyota badges, or someone might have re-badged their Scion. -
Lol...
I just saw that commercial. It doesn't mention Toyota, and 'maybe' it's saying it's the first boxer with that special injection/ D4S and direct injection tech. w'ever. I'm not sure though - there's a LONG pause between the different statements.
