105
yeah, the problem with inexpensive sports cars is who gets them and how do they drive and maintain their vehicles. That said, I bought my 06 WRX wagon in my 50s ! if you're looking for a project car, I guess almost any of them would be OK. Personally, 06-07 WRX would be decent. Some folks really don't like the samurai face, pignose, flying va-jay-jay look of the front but, mechanically they're awesome stock and have lots of potential for upgrades. yes. I'm biased.
the conditioner only helps, and is only promoted for, external 'weeping' of coolant. I don't think it will harm anything if used appropriately. I have heard of people using other products for bad HGs - I'm just skeptical it works very often or for a long time. Combustion chamber pressures are much higher than cooling system pressures and I doubt any high-tech substance in the coolant can even be deposited where it needs to go.
R.I.P Roger "Tobias" Roberts
1 Lucky Texan replied to Skylar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so sad -
check engine light went off
1 Lucky Texan replied to 1990loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
many codes will clear after several drivecycles if they do not reoccur. I've had a weak battery cause spurious codes on the wife's OBW, and recently i had a scare with my WRX but the codes never repeated. Also, on older vehicles, you could have dicey/intermittent grounds/cables,connectors that might create a false code. -
acoustic coupling and damping is crazy stuff. I worked on some acoustic downhole instruments for a while (as a tech) in the wireline biz. We had to put some crazy bends in some tubing, add steel/lead cylinders of a certain dimension, couple things together with rubber bushing between everything - slide all that into a steel sleeve with slots cut out of it, all in an attempt to slow down and suppress the sound of the xmitter coming down the through the tool itself so formation travel time could be measured. fun stuff. The point made about about the frequency being detected is good, as is concerns about mods/changes to the engi ne configuration. With my luck though, if I moved it, the a/c clutch or some clunky brake/clutch linkage, or a relay would probably create false knock impulses. Or some worn out acc. belt bearing would mask the real knock sound or otherwise work to my disadvantage. I'd put it back where 'they' had it.
Lol...
1 Lucky Texan replied to TheSubaruJunkie's topic in BRZ and its Sister the Scion FRS/Toyota GT86
gosh I....I hope I can hang on long enough to witness that glorious day! :cool: -
ebay deal is a little cheaper than the Dorman box of 10 I'm still working on. http://www.amazon.com/Dorman-095-142-Drain-Plug-Gasket/dp/B001SNRGAA/ref=sr_1_1?ie=UTF8&qid=1341245887&sr=8-1&keywords=dorman+subaru+washer+gasket+oil but, if I was really packing on the miles, Fumoto would be the way to go.
Lol...
it may just take a little time. after all, SVX owners are here. -
I understand, - recently used 'regular' seafoam on my WRX - I used the vacuum line off of the BPV on the 'front' of the TMIC. But, some folks say it only gets thru 2 intake runners so - I dunno. like you, I'm reluctant to engage in a huge amount of fiddly dis-assembly. I may have to eventually, but for now, my car seems to be OK.
If you had filled up, then reported stalling within a few blocks/miles (???) afterwards, perhaps water in the gas 'might' be at fault. but 35 miles+ after filling up - seems unlikely to have been bad gas. did the CEL come on? even if it didn't, there might be a pending code. Try to get the OBDII system read with a scanner for codes. If you can also get freezframe data, fuel trims might be interesting to look at. any rain or driven through a puddle? maybe moisture splashed onto cracked spark plug cables.
