105
R.I.P Roger "Tobias" Roberts
1 Lucky Texan replied to Skylar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so sad -
check engine light went off
1 Lucky Texan replied to 1990loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
many codes will clear after several drivecycles if they do not reoccur. I've had a weak battery cause spurious codes on the wife's OBW, and recently i had a scare with my WRX but the codes never repeated. Also, on older vehicles, you could have dicey/intermittent grounds/cables,connectors that might create a false code. -
acoustic coupling and damping is crazy stuff. I worked on some acoustic downhole instruments for a while (as a tech) in the wireline biz. We had to put some crazy bends in some tubing, add steel/lead cylinders of a certain dimension, couple things together with rubber bushing between everything - slide all that into a steel sleeve with slots cut out of it, all in an attempt to slow down and suppress the sound of the xmitter coming down the through the tool itself so formation travel time could be measured. fun stuff. The point made about about the frequency being detected is good, as is concerns about mods/changes to the engi ne configuration. With my luck though, if I moved it, the a/c clutch or some clunky brake/clutch linkage, or a relay would probably create false knock impulses. Or some worn out acc. belt bearing would mask the real knock sound or otherwise work to my disadvantage. I'd put it back where 'they' had it.
Lol...
1 Lucky Texan replied to TheSubaruJunkie's topic in BRZ and its Sister the Scion FRS/Toyota GT86
gosh I....I hope I can hang on long enough to witness that glorious day! :cool: -
ebay deal is a little cheaper than the Dorman box of 10 I'm still working on. http://www.amazon.com/Dorman-095-142-Drain-Plug-Gasket/dp/B001SNRGAA/ref=sr_1_1?ie=UTF8&qid=1341245887&sr=8-1&keywords=dorman+subaru+washer+gasket+oil but, if I was really packing on the miles, Fumoto would be the way to go.
Lol...
it may just take a little time. after all, SVX owners are here. -
I understand, - recently used 'regular' seafoam on my WRX - I used the vacuum line off of the BPV on the 'front' of the TMIC. But, some folks say it only gets thru 2 intake runners so - I dunno. like you, I'm reluctant to engage in a huge amount of fiddly dis-assembly. I may have to eventually, but for now, my car seems to be OK.
If you had filled up, then reported stalling within a few blocks/miles (???) afterwards, perhaps water in the gas 'might' be at fault. but 35 miles+ after filling up - seems unlikely to have been bad gas. did the CEL come on? even if it didn't, there might be a pending code. Try to get the OBDII system read with a scanner for codes. If you can also get freezframe data, fuel trims might be interesting to look at. any rain or driven through a puddle? maybe moisture splashed onto cracked spark plug cables.
have it scanned for pending codes. maybe you have a sticking valve. seems unlikely to be a TB issue since it's intermettent. might be good to put a vacuum gauge on it and start moving pushing pulling on hoses and harness bundles. If you can make it stumble, then investigaet for cracked vacuum lines. If vacuum is steady and it stumbles, look for loose connectors, bad wires, etc. has the car generally been well cared for? plugs and fluids changed per schedule, etc. ?
when diesel boxer come-out?
1 Lucky Texan replied to Suba_GL_87's topic in Meet n' Greet. Your USMB Welcome Center
this is a thread posted by a guy putting the EE20 in boats; http://www.ultimatesubaru.org/forum/showthread.php?t=125146&highlight=boxeer -
oh yeah, I thoght he meant as an option in a vehicle. check here; www.boxeer.com there's also a coupla vids on youtube of one swapped into a *OOPS!* - yeah, I thinks it's a Vanagon. -
I think fairtax has a great post. but cnydauve raise the question - somewhere there is a pressure sensor that must tell the pump to shut off. maybe it's 'on' and shuts the pump off too soon or at too low pressure. Might be worth pulling some plugs to see if an injector is leaking/stuck open. where's mccracken, he needs to come back until we ...................... . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . RELEASE MCCRACKEN !!!!
I don't keep up with Subaru News & Rumors but, due to diesel emissions regulations and maybe other reasons, I doubt there are plans to bring it to the US. They sell fairly well I think overseas. maybe 20% of sales in Australia.
