105
dunno how many fuses are involved or where they'r located. But, you need to hear the relay click so, once you've tried a different relay(the coil could be bad) it's time to trace the circuit (wiring/fuses) from the switch. If the relay is switching and the contacts aren't burned off (try a different relay) then the circuit from there to the back , as well as the ground for the defroster (this could be in the harness that gets flexed so much from the hatch to the body - might be a bad wire???) , all needs to be traced out. There are repair kits for cuts in the defroster traces themselves, if that is part of the problem.
nothing wrong with doing an alignment, hope it helps. maybe double check lugnuts and other stuff. Could also be you got a little air in the PS system and it needs a little time to work its way out, dunno - just seems weird. When the car comes back from alignment, get back here if the problem persists. I might not be much help, but someone probably will!
that rag soaking thing does seem familiar. The only test you can find on the 'net was for PB Blaster, Kroil and other off-the-shelf penetrants, but in that test, the best was 50/50 mix of acetone and ATF fluid (dexron III I guess) - have to shake it up before use. still, may not work for this severe rusting. As for heat, I'm sure the knuckle gets plenty hot in normal use - but excess heat could definitely be an issue. If you could keep it localized - then flood with cool/cold water......thermal shock might be helpful.
shards sounds bad, but a 1/4 - 1/2 teaspoon of 'filings' is likely normal. Doesn't mean a chunk isn't lying in the bottom.... Search for the term 'torque bind'. If you have mismatched tires, or certain types of failures associated with the center diff (MT) or 'wet clutch pack' in an auto-tranny - you can get that 'jerkiness' when maneuvering tightly in a parking lot. One or 2 other issues can be similar. more info about the car, what tranny, the tires etc. might help someone suggest the next step.
got any pics of your boats?
What should I take from this 89 XT6?
1 Lucky Texan replied to ABawm 88 GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
does...gulp....does it have rear LSD?
