1 Lucky Texan
    105
  1. Got beat by about 5:30 - have 2 left to go. The driver's rear plug (actually, the coil) is the most difficult. Anyone attempting this should go ahead and remove the windshield washer tank, then you can remove a metal cable shield - 2 10mm bolts. This allows the rear coilpacl to move around with less restriction. Even though I managed to get the coilpack out of the way, install the plug, I could not get the pack back on. I used my floor jack, a piece of wood and put some upwards pressure on the dvr's side motor mount area of the engine. Just about 1 - 1 1/2 pump of the handle. This gave me just enough xtra clearance to rotate the coil around. Surprisingly, the new plugs seem to go in with little concern about cross threading. I did use anti-seize on the threads. And you can easily feel when they have bottomed so, putting another 1/2 turn or so on the plugs is not too difficult. I also put a little dielectric grease on the lower body part of the plug think the tube on the coil pack might make a more contamination resistant seal. Gonna get some iced tea and attack the remaining 2 DS plugs.
  2. second plug out - who's got the stopwatch? lol! getting some tea, taking a ... it's a horrible job, hands and fingers already cramped.
  3. first plug is out - this job is not easy. plfr6 w'ever stock plug that I got out is over .040 gap (1 mm wire gauge passes through easily) the plugs i got from RockAuto (laser iridium Premium ILFR6B 6481) are about .030-.031" or so. I find conflicting data online as to what the gap should be, but, since these are different plugs/slighly different technology, I guess I'll put them in as is. Everyone claims not to adjust NGK so, I'm trusting these will work.
  4. OK, RockAuto sent me (a year ago) NGK ilfr6b 6481 'Laser Iridium Premium' plugs. While I can find them on NGKs .pdf catalog, I can't confirm they are appropriate for my 03 H6 Outback doing a brief 'reverse' search. The gap is .031" or so on all 6. When I use the part finder portion of NGK's website, I get a different (maybe newer?) part listed in Iridium, and it shows a gap for that part of .044"
  5. today, I worked on the wife's 03 H6 OBW. synth oil and oil filter airfilter swapped about 2 pints of old PS fluid for new. (turkey baster with hose, sucked out the tank, filled to mark, idled car and moved the wheels a few times. Then emptied tank again and refilled) drain/fill about 3.5 qts of transmission fluid. Used the Subaru ATF-HP. I plan to do this again in October, then again next April. BUT, I discovered the boot on the driver's side is now torn!, I just 6 months ago installed struts and the pass side axle. We're gonna drive it as is for at least 6 months. Just don't feel like tackling that right now cause....I need to put plugs in!!!, I guess I'm gonna give that a try tomorrow. It looks impossible. also, can anyone confirm that, the thing missing it's hose near the middle of the following picture is the PCV valve on an 03 H6? ;
  6. Today I did some work on the 03 H6 OBW. I need to change the plugs. It's looks impossible. Yes, people 'claim' to have done it, Yes, I've read everything I could about it. The distance in the back between the coil pack and the frame is less than the length of a sparkplug! And, if the thickness of the coilpack is gonna allow for a 'turn' into the sparkplug 'tube' then it looks like the coilpack can't possibly get out of its 'well'. And, do I just shove the coilpacks out of the way? They have connectors on them, do I lift a tab or squeeze them somewhere to pull the connectors off? (I wouldn't mind doing this, I believe in 'wiping'/reconnecting connectors generally, then i'd coat them with dielectric grease to reduce contamination.) How likely am I to slam the electrode shut on the sparkplug trying to get it started? Can I slip it into the tube already in the socket? I have bought a wobble extension and a 5/8 sparkplug socket, with no rubber or magnet inside (I only had 13/16). I also have some universals and other tools. I plan to attack from underneath. I may do the 2 front ones, then the driver's rearmost to get it outta the way. Does this seem like a good plan for a noob?
  7. ^^^ yep - hope it isn't the center diff. Tires must be same model/inflation and wear (to within 2 or 3 32") you might get under there and check axles and u-joints too, but those are longshots.
  8. PORCELAIN Veyron !!!! http://www.dailymail.co.uk/news/article-2132581/Thats-cracking-motor-Brave-owner-parks-unique-1-6m-Bugatti-Veyron-supercar-PORCELAIN-Paris-street.html?ICO=most_read_module
  9. threw synth oil, new oil and air filter onto the 06 WRX wgn. Inspected stuff, vacuumed leaves off the cowl area....probably check tire pressure in a minute... Work on the 03 Outback this weekend and maybe next week too. Needs plugs (ugh). brought the 'car dog' out front with me while i worked in the garage.
  10. isn't this normal behavior? I suppose, you could pull the fuel line loose at the filter and relieve the pressure - maybe drain a little fuel out - then reconnect. Then, see if the pump runs a little longer to pressure up the system. what problem are you having with the car?
  11. front fire and then back fire , not each bank. 12 fire, begin power stroke down ----- 34 begin compression 34 fire, begin power stroke down ----- 12 begin exhaust 12 begin intake ----- 34 begin exhaust 34 begin intake ----- 12 begin compression repeat the last two actions occur with just the force of inertia from the flywheel. Unlike normal when each compression stroke is powered by one other cylinder's power stroke, that only happens with the second firing pair in this 'big bang' scheme. that is, one pair's compression stroke relies on inertia alone. That's why I suggested you may need more flywheel mass/effect. There's gonna be some increased torsional forces on the crank and flywheel parts too. it's gonna sound like a harley
  12. you have to shift the plug wires to fire the cylinders that just finished their compression stroke so, the ones at TDC immediately after close of intake valves. and because it's a boxer - it must be the cylinder on the other side. So, either 1 & 2 will fire, followed immediately by 3&4 - followed by a long pause, then repeat OR 1&2 will fire, followed by a long pause, then 3&4 will fire, repeat.
  13. not trying to derail the thread but, check into the top-of-the-line battery from O'Reilly. It might be a good replacement for your Optima. They are absorbed glassmat with some kinda new silver based technology and they are true - sealed/no maintenance. I think made by DEKA. Might not be perfect for extremely cold weather, but down here, reserve capacity is more important than CCAs. Average lifespan for our batteries is only around 3 years or so! I've gotten free replacements a coupla times on the Autozone Gold level batteries, but the O'reilly ones are about the same price with better prorating after the 3 year full replacement. just fyi
  14. everything is a compromise for function, weight, cost, durability, etc. lots of pressure on aftermarket stuff to be cheap so, they go with smaller wire or wimpier insulation or make you move connectors over, etc. Plus, you may trade or junk the car before experiencing a failure from a lower quality part - just because they know it's going on a used vehicle, perhaps one closer to the end of its life than beginning. If you KNOW you're gonna keep this car for a long time and want to minimize the possibility of a part-related failure, it's hard to argue with buying OEM or similar quality. This may not be quite as critical for something like battery cables, but it isn't bad practice to investigate and insist on good parts. Perhaps the parts store has a better aftermarket than the one you purchased. Frequently there are 2-3 'levels' of quality available in the aftermarket product world.
  15. I've seen inflatable blasting 'cabinets' - but not one big enough for a rim. I'd think you could put together something with PVC pipe. No good for a shop, but at home you may only need to blast something every few months so, a 'knock down' unit of some type would be OK. Might even be some good plans around at instructables or somewhere on the web.
  16. if that coolant isn't going into the oil sump, coming out of the gaskets, a hose, waterpump weep hole or the o'flow bottle - it's leaving via a combustion chamber. from waht I've read, HGs are notoriously resistant to pressure testing, they fail after heating up on the road. Try a chemical test for combustion products in the coolant, find out if the overflow bottle appears normal or is filling up(bad rad cap or small o'flow hose). Make certain the engine oil looks good and is the proper level. Doa any topping off with the nose of the car elevated and recheck the coolant level after the next drive cycle. Soobs often need to be burped. Did this problem show itself after any maintenance, mods or a wreck?
  17. ran across references to 'big-bang' engines and then saw this wiki article about several weird firing sequences tried in motorcycles; http://en.wikipedia.org/wiki/Big-bang_firing_order#4-stroke_V4
  18. make a good airboat/hovercraft motor I bet - flywheel effect from the prop would be helpful. and disty/carb equipped would be easier to set up I think. I recall a 'nature-type' program once where the guy converted a small in-line 4 to steam. Used it to motor up/down the Amazon or Rio Negro using driftwood for fuel.
  19. most likely what they said - just mentioning I've had bad tires do something simialr to this - belts showing/tread separation on the inside shoulder area.
  20. You should probably start with wiki or howstuff works. There are different types of limited slip devices. A couple of types, most recently viscous coupled, have been sold on soobs, and aftermarket LSDs that never came new on soobs. vicsous probably the easiest to model. edit; here's some info; http://www.houseofthud.com/differentials.htm
