105
um, paging @lmdew ?
air cut valve pump. It comes on for maybe 45 seconds on a stone-cold start. Some cars need to keep one ofr the valves for an air pressure sensor that's in it? Others can remove the valves and pump. Some companies made block-off plates for the valve locations. My valves rusted shut after about 4 years so, I just killed the codes but left the parts in place. I think I deleted about 14 codes on my WRX.
4x140 to 5x100 bolt pattern adapters
1 Lucky Texan replied to matts87glsedan's topic in Products for your Subaru
paging @Loyale 2.7 Turbo , he is in Honduras but may have a suggestion. -
dunno for certain but, my total guess is , very likely to start and run. I had to kill 12-16 codes with romraider/ecu flash to fix similar issue with my wrx. on some cars, there is an air pressure temp sensor in one of the air cut valve modules so, watch for that. generaldisorder, and maybe others will know the details
yeah, I think if I do anything, I'd lean towards a gas dryer - just thinking about the temperature/humidity cycles until I get to that last few gallons...wait as I type this, I realize a good approach may be to just fill-up sooner! less atmosphere 'head space' . I think I'll start refueling at 1/2 tank and see how that goes.
any indications someone in the past tried to add HID lamps or other modes?
