105
tell him to search for either a CAI (cold air intake) or 'short ram' intake. boxer4racing probably has some legacy/outback specific stuff. He won't see any difference except in noise under the hood.
hmmm, I can tell you on my wife's 03 H6 with weather package, the right rear will spin the left in the same direction (LSD). however, I'm not sure I've tried it the other way. I will try it in April when I plan to do some maintenance. But, I'm not really sure I understand your question. Also, can you be more specific about the vehicle and what direction you expect the wheels to turn? Someone else here may already know how to answer your question.
I didn't see Subaru listed as an exception at the scangauge compatibilty page. Does your car's emission sticker have OBDII printed on it? Did your car perhaps originate in Canada? Maybe re-post your question with a thread title like 'Scangauge Users' and see if anyone has help for you. Or email Scangauge. http://www.scangauge.com/category/support/faqs/compatibility-faq/ http://www.scangauge.com/support/compatibility/after-1996/
If it's OBDII, should be good to go. There were some very cheap code readers from ebay or Harbor Freight that folks had trouble with. They wouldn't read the ISO protocol used by Subaru. But that was a long time ago I read about that. If it doesn't read, you might be able to read the OBD I system with a blink code and the black (or green?) connectors. http://www.ultimatesubaru.org/forum/showpost.php?p=428662&postcount=9 http://www.ultimatesubaru.org/forum/showthread.php?t=81497&highlight=black+connectors
I'm pretty sure OBDII allows for 'some' manufacturer specific codes, but most will be 'universal'. And, there are 4 (IIRC) 'protocols' for communication. The emissions sticker - usually on the underside of the hood?, should have OBDII printed on it if that's the system installed. might look similar to; what codes are you getting or are you having problems reading the codes?
Unusual 4x140 Wheel?
1 Lucky Texan replied to Tatarusbrute's topic in Old Gen.: 80's GL/DL/XT/Loyales...
LOL! now I think of it, I've been to Moscow Texas! -
your english is excellent. -
As I do different things on my cars, I always retighten grounds when I see them. I dunno if I'd take the time to hunt them all down unless I was having problems related to them. If I lived in wetter/salted roads parts of the country, I'd probably retighten them and then smear dielectric grease on them.
If there's enough slack (unlikely) you can cut the old term. off, strip back some insulation, and put the new term. on. Otherwise, you may need to buy the entire cable from a dealer. If it is old (4-7-10 years?) it likely has corrosion creeping down the strands inside the insulation anyway so, a new cable is better that what you have now.
around here, batteries last an average of about 3 years. I don't have an Optima, but for about the same money as Autozone's top of the line, I got O'Reilly's supreme/super start w'ever battery (I think it's made by DEKA ?) which is some kinda advanced technology (AGM with silver ?) and a true zero maintenance. There is no way to add or check the electrolyte. (And less corrosion on top so far) Very long replacement and pro-rate warranty too. So far, it's been fine. Other folks that are into motorsports want lightweight batteries. And, as mentioned some folks might have high-demand accessories. So, there could be good reasons to 'upgrade' for some folks.
You could try the old test for stuck exhaust valve, hold a strip of paper at the tailpipe while cranking. If it 'sucks in' then there may be some bad valve timing. Another thought, (carefully) take the hose loose at the fuel filter and see if there's pressure. There is an odd failure to some fuel pumps on this model. maybe just no fuel is being sent to the injectors.
there are posts on this and other subaru forums too. But an 05 is unfamiliar to me, but any PS system sucking in air will have a problem. Again, monitor the PS fluid tank. I had to remove the intake runner - 2 bolts, to get a good eye on mine. It was bubbling and foaming. After I fixed it with an o-ring from Ace Hardware, it just showed a little flow, no more bubbles. I also, used a small hose attached to a acheap turkey baster to replace much of the fluid with the owner's manual recommended fluid as the old fluid was quite dark and I assumed contaminated with moisture from the suction leak. Quite and working fine now. Of course, you could have a completely different problem.
any t'stat other than from the dealer is suspect. Stant Xacstat might be OK but I don't think there's been a lot of feedback on those yet. There's another brand out there too that seems like a direct replacement. Certainly, typical small aftermarket t'stats are known problems. Also, the system is prone to holding air pockets. Some people even recommend parking with the nose up on a curb to help move air out of (burp) the system. There are several ways to proceed. Are you losing fluid or is the overflow bottle filling up? Are there bubbles in the coolant? Seems like your radiator fans are working OK, but doublecheck them. Is the coolant clean and clear? has the system been well maintained?
