105
last week, my wife used the Groupon I got her for her birthday and had the outback detailed, today, I checked all the fluids and prepped her car for a 5 hour drive to Galveston tomorrow. My company's founder is taking all the employees and their spouse/SOs on a cruise to celebrate the company's 30th anniversary. (see how I used a thread about car care to make you all envious? - MWAH-Hah-hah-hah-haaaahhhhhh!!!)
hmmm....seems to me this is an accessory belt issue and you 'may' be looking at the tensioner or other item driven by an accessory belt - not timing belt(which drives the water pump). Also, is this car a 3.0 H6? The serpentine belt runs across 2 pulleys that are known problems. Tensioner pulley and idler pulley. There's 1 or 2 threads devoted to that problem.
The Awesome Vehicle Picture Thread
1 Lucky Texan replied to TheLoyale's topic in Non Soob Cars and Bikes Discussion
^^^^this
your usage is low like both my cars. That is often considered a 'harsh environment' as moisture may not get driven out from fluids well with short/infrequent trips. You might find DIY instructions here or at scoobymods for the front diff. perhaps even a video at youtube. It wasn't too difficult but I had to buy a T-70 torx from AutoZone ($5 or so IIRC) a 2002 might have a hex-head, not sure when they switched on which models. I also bought a funnel with a hose attached from amazon. I used Lightweight shcokproof synth. but many folks claim the OEM and most other GL-5 fluids in the range mentioned in the owners manual are just fine. Automatics have a'wet clutch pack' that lives in the same fluid as the tranny. You should consider doing a 'drain/fill' at least on the transmission. That gets about 1/2 the fluid changed. 3 cycles would be considered close enough to a complete change. There are more extensive approaches to transmission fluid change/flush.
All I can offer at this point is, after I replaced the lube in our Outbacks diff with synth. the whine got a little quieter. This is refereing to the normal whine I could hear - mostly at highway speeds. NOT some condition that came on later, it was always a little noisy. It does seem as though you have the condition localized so, I suppose some type of repair may be in order. I do agree with you that, a low fluid condition 'might' not lead to the problem you have - though you haven't mentioned how many miles are on the car - or more importantly, how many miles since the last (if ever) front diff fluid check/change. If it was low from the fcatory and never serviced, and you have 100,000 miles - then yeah, I suppose that could be a problem. the devil is in the details. There is a magnet on the drain plug - inspecting that and perhaps uploading a pic of what that looks like, might get some useful comments from others here with more experience as to what would be 'normal' vs and obvious overabundance of metal shavings. On my car, there was, perhaps, 1/4 teaspoon of material on the magnet. I doubt much more - maybe less. Could be pinion or other front diff problem I guess. Not good news if so - maybe read this; http://www.ultimatesubaru.org/forum/showthread.php?t=106831&highlight=backlash&page=3
hope your wife is doing better. this is an odd problem. Does the sound change during a left sweeping turn vs a right sweeping turn? Wheel bearings will make noises when they are going bad. After driving, see if one hub feels warmer than the other. If you have an infrred thermometer, take some readings of the hub area of the wheels after a drive. Just to be clear, seems like, from the way you mentioned the front diff, this is an automatic? If so, you should know the diff is the stick on the pass side(US) - and the transmission is on the driver's side - right? (hope this is the same arrangement as my wife's Outback) Are the tires in good condition?(all the same model and wear conditions) maybe inspect the inner edge of the front tires for exposed steel belt. Even rotate them front to back to see if the sound changes. Are the brake pads worn? Does the sound change with brake application? maybe the squealer on the pad(s) is dragging. (seems like you've looked at the tires though?)
they'totalled'my dual range touring model
1 Lucky Texan replied to touring's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Get on the phone, call soob dealerships, in several States if necessary, tell the used car manager you're an insurance adjuster and just need to know what an '89 like yours would actually sell for if they had it on their lot. That's about the best you can do. I had to do that when trying to negotiate for an 'odd' older car once - just to get a baseline. Also, if you could come up with receipts for recently rebuilt or new major parts - that could help get a little more. Do NOT do the above and THEN try to buy it back lol! -
dunno if a Forester is similar, but you might look at the top 3-4 pics here; http://lovehorsepower.com/joomla/index.php?option=com_content&view=article&id=48:1995-subaru-legacy-outback-timing-belt-and-water-pump-replacement&catid=10:subaru-legacy&Itemid=64 (and , farther down that page, more pics after some re-assembly)
did this begin after any service to the A/C? maybe check the charge - someone posted a problem from an overchage condition. But there there 'should' be over and undercharge switches to keep it from self-destructing. You could look in the power steering tank for bubbles if you're not sure where the noise is coming from. Seems like you only hear it when the A/C compressor is on? good luck
