1 Lucky Texan
    105
  1. why was it rebuilt? Might doublecheck the timing belt timing. If it was rebuilt because of TB failure, a leakdown test might find a bent valve. Maybe there is fuel starvation, might check fuel pump output. brief test with the exhaust loose might point to a clogged cat conv. - longshot on that.
  2. boxer4racing carries a few bits for legacy - you might dig around there. fun project!
  3. traveled DFW to Galveston in the outback (03 H6), then back after a cruise. 25 mpg down, 26mpg back. 65-80 most of the time.
  4. last week, my wife used the Groupon I got her for her birthday and had the outback detailed, today, I checked all the fluids and prepped her car for a 5 hour drive to Galveston tomorrow. My company's founder is taking all the employees and their spouse/SOs on a cruise to celebrate the company's 30th anniversary. (see how I used a thread about car care to make you all envious? - MWAH-Hah-hah-hah-haaaahhhhhh!!!)
  5. hmmm....seems to me this is an accessory belt issue and you 'may' be looking at the tensioner or other item driven by an accessory belt - not timing belt(which drives the water pump). Also, is this car a 3.0 H6? The serpentine belt runs across 2 pulleys that are known problems. Tensioner pulley and idler pulley. There's 1 or 2 threads devoted to that problem.
  6. CACA, IP Tension from the bottom, CCW C rank A / C A lternator I dler P ower steering pump T ensioner (I found it easiest to slip the belt over the power steering pump last while rotating the tensioner 'down' with a 3/8 breakover)
  7. your usage is low like both my cars. That is often considered a 'harsh environment' as moisture may not get driven out from fluids well with short/infrequent trips. You might find DIY instructions here or at scoobymods for the front diff. perhaps even a video at youtube. It wasn't too difficult but I had to buy a T-70 torx from AutoZone ($5 or so IIRC) a 2002 might have a hex-head, not sure when they switched on which models. I also bought a funnel with a hose attached from amazon. I used Lightweight shcokproof synth. but many folks claim the OEM and most other GL-5 fluids in the range mentioned in the owners manual are just fine. Automatics have a'wet clutch pack' that lives in the same fluid as the tranny. You should consider doing a 'drain/fill' at least on the transmission. That gets about 1/2 the fluid changed. 3 cycles would be considered close enough to a complete change. There are more extensive approaches to transmission fluid change/flush.
  8. All I can offer at this point is, after I replaced the lube in our Outbacks diff with synth. the whine got a little quieter. This is refereing to the normal whine I could hear - mostly at highway speeds. NOT some condition that came on later, it was always a little noisy. It does seem as though you have the condition localized so, I suppose some type of repair may be in order. I do agree with you that, a low fluid condition 'might' not lead to the problem you have - though you haven't mentioned how many miles are on the car - or more importantly, how many miles since the last (if ever) front diff fluid check/change. If it was low from the fcatory and never serviced, and you have 100,000 miles - then yeah, I suppose that could be a problem. the devil is in the details. There is a magnet on the drain plug - inspecting that and perhaps uploading a pic of what that looks like, might get some useful comments from others here with more experience as to what would be 'normal' vs and obvious overabundance of metal shavings. On my car, there was, perhaps, 1/4 teaspoon of material on the magnet. I doubt much more - maybe less. Could be pinion or other front diff problem I guess. Not good news if so - maybe read this; http://www.ultimatesubaru.org/forum/showthread.php?t=106831&highlight=backlash&page=3
  9. hope your wife is doing better. this is an odd problem. Does the sound change during a left sweeping turn vs a right sweeping turn? Wheel bearings will make noises when they are going bad. After driving, see if one hub feels warmer than the other. If you have an infrred thermometer, take some readings of the hub area of the wheels after a drive. Just to be clear, seems like, from the way you mentioned the front diff, this is an automatic? If so, you should know the diff is the stick on the pass side(US) - and the transmission is on the driver's side - right? (hope this is the same arrangement as my wife's Outback) Are the tires in good condition?(all the same model and wear conditions) maybe inspect the inner edge of the front tires for exposed steel belt. Even rotate them front to back to see if the sound changes. Are the brake pads worn? Does the sound change with brake application? maybe the squealer on the pad(s) is dragging. (seems like you've looked at the tires though?)
  10. I would likely never tighten anything with my new electric impact. And, I would avoid using it for loosening 'long' bolts as they might snap where steady pressure would loosen them. But for removing the axle nut, it's awesome!
  11. Get on the phone, call soob dealerships, in several States if necessary, tell the used car manager you're an insurance adjuster and just need to know what an '89 like yours would actually sell for if they had it on their lot. That's about the best you can do. I had to do that when trying to negotiate for an 'odd' older car once - just to get a baseline. Also, if you could come up with receipts for recently rebuilt or new major parts - that could help get a little more. Do NOT do the above and THEN try to buy it back lol!
  12. It appears the AVCS after about MY '05 does not get a screen? it isn't clear if turbos still have this screen? If not, what year did they drop or change the screen?
  13. dunno if a Forester is similar, but you might look at the top 3-4 pics here; http://lovehorsepower.com/joomla/index.php?option=com_content&view=article&id=48:1995-subaru-legacy-outback-timing-belt-and-water-pump-replacement&catid=10:subaru-legacy&Itemid=64 (and , farther down that page, more pics after some re-assembly)
  14. yep, and I still have the stock springs from my 06 WRX wagon. They have less than 1000 miles on 'em. I got wagon-spec SPT pinks installed early on. if you decide you need something like that or need the free length or diamter w'ever measured, PM me.
  15. did this begin after any service to the A/C? maybe check the charge - someone posted a problem from an overchage condition. But there there 'should' be over and undercharge switches to keep it from self-destructing. You could look in the power steering tank for bubbles if you're not sure where the noise is coming from. Seems like you only hear it when the A/C compressor is on? good luck
  16. wish I had thought of using a dogbone wrench like that! That would have been a much more useful item afterwards and less hassle overall.
