105
I admit any valve overlap should create a 'negative pulse' that could make the test confusing. And another thing is the bernoulli effect (I think, maybe venturi?) that could make the test a little confusing. To illustrate, find a Post It note or use a strip of paper - even the corner of a full sheet. If you place it very close to your pursed lips while blowing steadily but strongly, there is a point, up close/touching, that has a vacuum feeling. Even pulling a millimeter away, and the paper is blown away, but if you force it up close again, it will appear to stick or suck back TOWARDS the stream of air. I suspect I would have to acquaint myself to how a normal car performs with a dollar bill or other piece of paper - probably several cars, before I could rely on myself to use the test for diagnosing slipped timing or a bad exhaust valve. And with interference engines, maybe by the time it's VERY obvious the paper is behaving in a way I could feel confident about wrong valve timing, there'd be a lot of noise from bent/broken parts!
The Awesome Vehicle Picture Thread
1 Lucky Texan replied to TheLoyale's topic in Non Soob Cars and Bikes Discussion
as awesome as this is; I think it just got obsoleted by this; -
After a long drive, use one of those remote infrared thermometers and measure the temperature of the hub and caliper and rotor. Compare to the other side. If those 3 things are about the same temp. , you know to look somewehere (where?????) else. But, even when my bearing was making horrific crunching noise, the wheel only moved 2mm or so, ANY movement means there's a problem somewhere. Don't forget to look at the inner tripod joint. If you still can't locate the problem, you could swap left-right CV axles and see if the problem changes or follows the axle.
I'd say the first step is to have a knowledgeable person check it out. You posted your location, so maybe someone can mention a mechanic that can confirm you have an internal transmission problem and not just a bad axle or driveshaft u-joint or other less severe problem. Although axle problems might hold for a while, get this investigated soon.
how to deice a window
1 Lucky Texan replied to ontherun987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that's how Chuck Norris de-ices a window. (know what's behind Chuck Norris' beard? ... another FIST!) -
1938 Phantom Corsair (aka The Flying Wombat) 1935 Stout Scarab 1938 Bugatti Atlantic -
Yep, that's was him on NASIOC. Nick over there could help you, or just join up and do an 'advanced search' on the name ' yardhippie ' and you'll find threads in which he posted. edit; here's a link to threads with a post from him, searching within the threads is required to ge his posts - again, email/contact Nick or one of the mods there. They may have a way to filter all of your son's posts and replies for you. http://forums.nasioc.com/forums/search.php?searchid=27208917 good luck
Looking to put an ez30/EG33 into an xt6
1 Lucky Texan replied to natext6's topic in Subaru Retrofitting
I believe the 04 and up got the AVCS w'ever it's a called and a few more ponies. And all-weather package (maybe others?) Outbacks got a limited slip rear diff too IIRC. Don't know what years, but my wife's 03 has one. dig around at cars101.com for features associated with the H6. subaruoutback.org, and NASIOC might be good resources too. this sounds like a wild transplant! -
OK, just a stupid thought but, there's no way the battery has been connected in reverse, or the car jump started with reversed leads I suppose? might explain some of the subsequent electrical problems, and maybe it threw off the timing if the crank was spun backwards? Is that possible? Doesn't seemlike the solenoid would work but I'm not sure with all the bypass jumpering........ The only time I've heard of engines being spun backwards is from tow trucks picking up FWD cars and dragging them off. Throws the TB off sometimes. I know - a real reach.
