105
that magnum seems more practical - and accesible - than that british zero. Hmmm- wonder if anyone has transplanted a Prius drivetrain into a lighter 'kit' type car? Carl
fyi http://blackjackzero.com/mainindex.htm
Yep, with 4 wheels 'hooked up' there's less 'burnout' and more 'break off'(of gear teeth). It can be a problem with stock power. Kids think they can rev to redline and sidestep the clutch with no consequences. 'Dog tooth' (RA) gear sets (full or sometimes first and second only?) are a stronger - if noisier - set up. That's what Ive read anyway. probably someone here has some experience with that. Carl
I plan to continue using Shell Rotella 5-40 in my WRX in summer and 5-30 in winter. Both synthetic. So far, I stick with 5-30 in the wifes 3.0 OBW. I would probably switch to 5-40 if it began using oil from wear, but it is still young in mileage. this of course is in Texas. interesting to see the 5-50 development. Could be helpful for some folks I suspect. Carl
I'd put the EBC Yellows on your list. At present, I plan to use them when I swap out the OEMs on my WRX. BTW - the OEM pads have survived MUCH better than expected, even after 3 track events. Also, Valovoline SynPower fluid might be worth a look, if your fluid's getting old, - good value for occasional high-performance demand. to save a little money on OEM try here; http://www.subarugenuineparts.com you could also look here for info; http://www.subarureview.com/ Carl
My wife has an '03 OBW and has the opposite complaint - it does not auto-lock when exiting the vehicle (like her van did). I THINK I read there is a set of connectors under the driver side door sill or behind the panel in front of it that will enable the auto-lock feature. Dunno if it requires any special attention to the alarm. Perhaps the alarm would still need to be activated. Maybe a dealership (or close look through the manual) could explain the feature? Carl
Hrmm KYB
1 Lucky Texan replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
An alternative might be to have Dale Teague at boxer4racing install Koni yellow adjustables in your (or core swap) struts. You'd need to email him about your year/model. Otherwise - what they said. I THOUGHT I read KYB makes soob's struts. Carl -
HOly crazy russian offroading... things...
1 Lucky Texan replied to Andyjo's topic in Vehicle Videos Online
how about Foresters in Russia! -
Dale Teague at www.boxer4racing.com has a few legacy perf. parts. Dunno about an intake. Carl EDIT: CONE to MAF adapter - $20 INJEN intake; But i dunno what years/models they fit - probably need to email Dale to confirm. I am just a happy customer - got my muffler from them. No other connection. Carl
yeah, from the link provided above; 8. Program remotes: works on Alpine system. Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time. Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up. When the horn honks, open and close the driver's door, press any remote button and that's it. Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it. When you're done, remove the key and the horn should honk 3 times. You're all set. Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again. OR take it to the dealer. I'd expect they could do that at no charge. Did you buy a replacement remote from EBAY or somewhere? I've heard on some systems the freq./code/whatever numbers on the back matter. Carl
Yeah, Arlington lake is pretty small, its a coolant reservoir for an electric utility and my citiy's main water supply. Not big and the 'yacht club' is tiny as well. It's just near my house and I took a few pics there once. you can see across the lake to one of the generating plants in this pic; Carl
I remember when the 06 came out and there was this long thread at NASIOC about how ugly it was and it looked like this or that. I asked anyone if they wanted to discuss the ;shorter throw shifter, conical 1st gear synchronizers, variable valve timing, air pump replacing front cat., alloy control arm, aluminum hood, diiferent IC, lower peak torque point OR the additional .5 liter displacement! I still think my car has the face of a Samurai warrior; please......, - folks in a SUBARU forum complaining about odd looking cars! HAHAHAHAHAHAHAHA! Carl
