105
You might enjoy the NA forum over at http://www.nasioc.com . Do a lot of reading and searching there before posting. And just overlook the smart-aleck remarks and keep digging and reading. Again - what do you WANT to do with your car? Suspension bits and 'looks' are easy, raw power will be difficult. A little lag can be helped with a lighter flywheel, lighter (but not under driven) crank, accessory pulleys. And lighter rims have some benefits too. Carl
If you could be very specific about exactly what you want in a car - folks could perhaps suggest the best way to obtain it cheaply. IMHO you can't really 'turn' any other soob 'into' and STI. Yeah, you can improve handling and acceleration and even do engine/drivetrain swaps. Still not as good as starting with an STI and probably more expensive. Do you want to autox? or drag race 1/8-1/4 mile? Is it the 'look' you're after? (my '06 WRX has a 2.5l engine - so are you looking at an older WRX or is the 2l still sold in California????) Carl
I suppose if you put excessively huge number of miles on the car AND/OR had a mobility problem preventing you from getting under the car but still wanted to do the changes yourself (or a stealthy way to do changes in an apartment complex) it looks like a workable idea. Otherwise, for the money - I'd rather have an oil cooler. Carl
Maybe a mech. could use an ammeter to measure resting current from the battery with alarm on and off. Perhaps there is a 'standard' amount that should be and if you have a parasitic drain it would show. If not, then increased capacity, remote charging or that drain prevention device would seem to be the only options.
No, I have just a regul;ar WRX wagon. To my knowledge the DCCD is only on the STI version of WRX sedan. I suppose the '06 MT legacies also got upgraded (conical?) synchros but I'm not sure. maybe one of these other guys knows. I just mentioned cause it seems to me, if it will bolt up and has no other negatives, may as well get an '06 or '07 5spd . Or maybe there is a rebuild kit with upgraded synchros you could throw in a low mileage junkyard tranny from a pre-'06. sorry - maybe someone else will know more specifically. EDIT; look about halfway down on this page; http://64.71.53.59/trannywr.htm#Transmission%20and%20Gears not cheap - maybe someone elses has a similar kit though for less. Or, wrecking yard '06 tranny if you can find one. I dunno Carl
One other kinda slim possibility is that the diode trio (actually, whatever does that job nowadays) in the alternator is bad. I've had alts be bad and not show up on dash warning lamps. And I also think investing in an Optima battery might be helpful. Or possibly have a shop rig a second battery in parallel with yours. Carl
Dilema
1 Lucky Texan replied to Dr. RX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There are a few 'spy shots' and some rumors of a Subaru 2 door hatchback for '08. No mention of a coupe though. If you don't need AWD there are tons of choices for you. Carl -
120K ? Has the timing belt already been done? If not, that might be the best time to consider doing the gaskets. If it has, then you must weigh the risk versus cost. Some folks say less that 20% of those vehicles will have a premature HG failure.There is no 'good' time for HG failure, but some very bad times, like on a long trip outta town with family in the car. Are you prepared to have the vehicle towed to a decent mechanic in a strange town? Depending on where you are, you could be hundreds of miles from a Subaru dealership - and if there is a warranty issue on their work, doubtful the local dealership would honor the it - not sure on that. Also, I didn't think the Subaru conditioner would help on Phase 1 engines? Carl
the usual culprits; up pipe, bigger turbo, down pipe and turbo back exhaust, bigger injectors and ecutek or other 'piggyback' or reflashed engine tuning. suspension and brake upgrades along the way too, maybe a clutch upgrade and better fluids for the tranny and diffs maybe. often Cobb and Vishnu and other companies sell 'packages' called stage 1, 2, 3 etc. . Carl
