105
It does seem a little weird, likely Autozone/whoever has someone pickup the oil, maybe for a fee - but AZ gets you back to their store, maybe you'll come inside and buy something. Its a service probably covered by slightly higher prices across the board. I dunno If 'disposal fees' get too high, folks'll just start pouring it over the fence or down the gutter. It's to everyone's advantage to make it easy to properly dispose of used oil, old batteries, mattresses, etc. Carl
If you have 'piston slap' it likely will not reduce the lifespan of the engine and certainly is not an immediate concern. Different oil may reduce it too. Oil loss(how much was it again?) could be something as simple as a PCV valve, oil pressure sender leaking, or a bad gasket somwhere(does it drip oil?). If it is blowby (has a compression or leakdown test been done?) that may help swing the decision to get a short block or reman. engine. Also, if a leaking headgasket can be confirmed, it would also point to the possibiltie of a new/reman engine I guess. I think, before spending that kinda money, I'd get a second opinion - even if it cost me $100 . Carl check with Emily at CCR about engines. And Jamie at www.subarugenuineparts.com can get OEM parts discounted - at least use those prices as 'bargaining points' to get your dealership to match part prices. Carl
If the issue with 'black stuff' in the radiator cannot be addressed/reapaired before the trip - rent a vehicle. many of the issues mentioned are common to ALL cars, just because they seem to occur at once, does not reflect on the Subaru or its age. Even IF it cost 4K (sounds like it may not need everything done at once if it runs well) that's like - what? - 15 new car payments? If you get another used car, it could very well have most of the same problems. If the car no longer meets your needs, yeah - consider trading it in - though, if its present condition is as poor as the neighbor suggests, it will be devalued. I say, no out of town trips as is, investigate further, address anything that needs immediate attention(raditor/headgasket, clutch, brakes), schedule things like plugs/wires, accessory belts, etc. over the next year or two. Even a bad CV joint will last for months. Carl
I'm using it in my WRX, to get the 40w rating at the top (it's 5w-40 IIRC). No problems so far but I don't really have a good number of miles on. I change oil every 4-6K so , even if it were rated a little below M1 in quality, I feel I'd still be getting superior lubrication to non-synth with a little 'lee way' should I be late on a change. I dunno (BTW - Rotella is a Shell Oil product) Carl
I have read (here I think) of someone using a portion of bicycle inner tube to make a pressure bleeder. Cut out a section with the schrader valve, fold one end over enough to be able to secure and seal it air tight, stretch the open end over the MC reservoior and secure with a hose clamp/whatever to make an air tight seal, connect to schrader va;ve and pressure inflate the tube. sounds like it would work - I dunno, haven't tried it myself. Carl
Although it is still low miles, our '03 H6 OBW has had only 1 'moderate' problem - A/C comp. hoses leaked out refrig., replaced under warranty. A coupla other minor problems also fixed under warranty. It has enough power to get on the freeways here in D/FW no problem - engine is glass smooth. Several times a year we load it up with show gear - no issues at all. I actually prefer our 03's interior to the '06 loaner I drove. I also once had a Forester loaner, it was OK, just seemed to have more body roll that ecpected. Plus, the seats were a little less comfy. Carl
Just a wild idea, it might be worthwhile to push/pull flex some cables around when it fails and try starting it. But crank sensor would be something that must satisfy the ECU before it will attempt to start the car. I don't recall - do you have a check engine light on? Can you get the code read? I think your car might be OBD II and borrowing a reader might be tricky. I dunno Carl
