1 Lucky Texan
    105
  1. At this point, that's a reasonable suggestion. I'd do that before assuming the new Temp Sensor was also bad. Anyone have any idea of voltage readings he could take at the temp sensor? maybe a voltmeter could at least confirm the sensor is good. I guess the 21 code comes back after the ECU is cleared? If so, it may be time to suspect the ECU itself in addition to a wiring issue. weird Carl
  2. I'll let you look for yourself - but if this link is right for your car, you're not gonna like what it says; http://www.ultimatesubaru.org/80s/specs/ecucodes.html Carl
  3. It might fit in the back of your Brat! hahahahaha! Carl
  4. ...in case its been missed - sorry if WTLW http://cgi.ebay.com/ebaymotors/RARE-1970-SUBARU-360-PICK-UP_W0QQitemZ4643071538QQcategoryZ6467QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  5. Just be a little more vigilant for a few days. One thing, it's usually not a good idea to start the car with the gas pedal depressed. I've read it can confuse the ECU. Do you normally need to hold the pedal down any to start the car? ('clear flood' - flooring it is different) Carl
  6. I had been thinking about ceramics and wondering if they were as low dust as folks say. I don't care if a pad is noisy - but I want it to be AT LEAST as effective, cold and hot, as OEM but would be willing to pay xtra for low dust and/or light colored dust (I have a white car and white wheels) Will ceramics 'bed in' on a used rotor or MUST they be 'turned' flat or new? Carl
  7. Reducing spinning mass will free up a few ponies for better acceleration mostly. Rolling resistance is tire related. For most of us, it comes down to a compromise between looks ,strength and weight. I saved about 3.5 pounds per corner - can't say I really felt the difference, but I like the way the car looks. Ultimately, if you don't get the ones that appeal to you, you might regret it. Carl
  8. My fear is you may have 2 problems. One related to the IAC mechanism or TPS or something. And the other - I dunno, A/C fan control relay or a bad wiring harness or ECU??? sorry - just wild guesses maybe your car has some diagnostic connecters that will give you 'blink' code? Carl
  9. http://www.boxer4racing.com no connection, just a happy customer Carl
  10. That gizmo might lead to more knocking - I'd be careful. Reducing rotating mass is a double win situation, less general weight and less rev-robbing mass - lighter rims do that PLUS reduce unsprung weight - triple win right there. Add the likelihood of improving/customizing the looks of your car - it's a no brainer. I upgraded my rims and saved 3.5 pounds per corner. If you have a MT, a lighter flywheel will help. Any other weight reduction will help. If you can tolerate the risks, run without your spare and jack/tool kit. Only keep 1/4-1/3 tank of gas. gas weighs -what? about 7 lbs per gallon? Do you NEED the rear and passenger seats? ( yeah, I know) seriously, rule of thumb says losing 8-11 pounds(I've read both numbers - probably depends on a ratio of power wieght at stock weight) is good for one hp. There are 1/4 mile calculation simulatoers on line where you can ebter the specifics of you car. Then you can play around with lower weight numbers and see the difference. Carl
  11. I THINK my wife's '03 OBW has some kinda connectors under the door sill that will enable an auto-locking feature but I've never investigated it. Maybe the dealership will know or try emailing Joe at http://www.cars101.com Carl
  12. My WRX came with it as an installed option I bought. I thought it was a bolt on - but '97 could be a lot different from '06 I guess. And it's 1 1/4" the number one installer of hitches in the US is U-Haul. I dunno if they have to drill or not. good luck Carl
  13. No drilling mentioned here; http://www.etrailer.com/products.asp?model=Legacy&category=hitch&year=1997&make=Subaru&t1=&h=e have you emailed Jamie at www.subarugenuineparts.com to ask if the OEM hitch requires drilling? carl
  14. Yeah, the auto is subject to ADDITIONAL abuse by improper maintenance - that likely is why it seems to be mentioned more often. And myabe sales of ATs is higher? dunno keep in mind, if you do have to buy tires a little sooner than you'd like, it really isn't a total waste - you're getting NEW tires! And, with AWD, you likely would have better performance with cheap tires than a 2WD car with expensive tires. So just get 'value' tires and rotate them. Carl
  15. One issue that hasn't been emphasized is the TYPE of driving being done on 'mismatched' tires. I'd expect surface streets, stop&go, or especially wet weather, gravel, etc. to be very forgiving of mismatched tires because any torque building up in the drive train has lots of opportunities to relieve itself. Driving on smooth, hard, dry pavement at highway speeds for long periods of time may be more destructive. Also, it may be possible to have the new tires 'shaved' a little to bring them to a closer circumference. Or one might run slightly less tire pressure to reduce the 'effective' radius - though of course that could lead to handling problems if taken to an extreme. (Cliff Notes) if you don't want to gamble with your drivetrain, rotate your tires and change all 4. if you must get a single new tire, shave it to match circumference to the other 3. Carl
  16. I've had good luck buying from jamie (subiegal) at www.subarugenuineparts.com so far. They offer '6 packs' of oil filters with washers for the drain plug as well as other OEM parts and maintenance stuff. I THINK there are replacement mirrors in the aftermarket - probably cheaper than OEM - dunno. There are other good vendors on-line too. try a search or maybe someone else will respond. If you buy after market filters, Try to find Purolater filters. decent value. Most people sya Fram is inferior but I think the 'Toughgard'/whatever midline quality might be OK - just Fram's cheapest is - well cheap. I don't think K&N is quite as bad as some folks make out - I'm just not convinced it really gives you much advantage over a quality paper filter - plus, if you're not very careful about re-oiling it, damage can occur to a MAF equipped car. This is just based on reading. I have no experience with K&N on a soob. I did once use an oiled filter(amsoil) on a Datsun. It was OK I guess. If you have done any repair work or made adjustments to the car since you got it, be sure to try resetting the ECU by disconnecting the neg. batt. terminal, stepping on the brake pedal, wait 20-30 minutes, and reconnecting the battery. It's possible the surging will be fixed. If not, maybe an O2 sensor is getting lazy or something? Carl
  17. oh yeah, the oil ? Oil is one of those issues that might start an argument, but I think you'd be safe starting with just about any 5w-30 oil. If you experience leakage or unusual noises/usage, or plan some 'severe' usage for your vehicle. get back to us and someone will have more specific suggestions. Also, there's interesting reading at www.bobistheoilguy.com Carl
  18. Dude, get that battery outta there, sprinkle some baking soda around everywhere you even imagine acis could have gotten, rinse it out, repeat, rinse very well. If you have an automatic transmission, there are 2-3 good reasons to do a full flush (not just a drain and change). Might fix the shift problem. Inspect brake pad wear, there is a 'squealer/tattletale' indicator on the pad backplate designed to , well, indicate by sound when the pads are worn. If the manual and the sticker on the door don't mention the air pressure, I'd start with 30psi or high 20s in the front, and 3 psi less in the rear tires unless fully loaded with gear - then increase a couple psi. www.cars101.com might have a link to your specs on tires and other stuff. If you don't have the service history on the vehicle, you could just need a brake fluid flush/refill. Some folks do complain about soob ABS but ,in general, it works. Occasionally I read about a buzzing noise from the ABS but I THINK its a bad relay. Service the brakes and see if it's improved. That mileage seems a little low for your car, it may have seen more surface street, stop/go type use than highway miles. Might benefit from a good suspension/brake inspection and a Seafoam or other 'top cylinder' treatment to blow out some carbon. Probably a new PCV valve wouldn't hurt. - generally, if you don't know the service history, inpsect and service everything now. make sure the tires are all the same size brand style treadwear too. hopefully others will chime in that have direct experience with your model. carl
  19. I've learned a lot since I've been hanging with these guys and other internet resources. One eye-opener was reading about 'warped' brakes at stoptech. http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml more interesting reading is also at; www.bobistheoilguy.com There are also a lot of people with good experience at detailing/waxing, power mods, 'transplants'(soob engines in non-soob vehicles) etc. Just ask around or try the forums at www.nasioc.com . Carl
  20. First, I wanna say that I am not so good at most of the advice I'm gonna give you - I am trying to do better! Be meticulous with tire pressure. Not only is it important to keep fuel mileage up (larger diameter ANd less rolling resistance) but , for soob owners, there's the added benefit of reducuing the chance of center differential damage. Drive as if there were eggs on top of the brake and accelerator pedals that must not be broken. Try to combine trips, reduce trips, eliminate multiple errands. carpooling will DRASTICALLY reduce your fuel costs - seems like no one does that much though. Be mindful of fuel costs relative to your activities. No point in driving 25 miles to save $0.40 on a pound of hamburger. Or driving at all when the internet price equals the store price! When shopping or for certain other errands - use the phone first. make sure the facility won't be closed or out-of-stock or something before you drive there. Keep the windows rolled up. Modern cars will get better mileage windows up and A/C on than with A/C off and windows down - this is more true at highwat speeds though. Save money in other areas to spend on gas. After tap water, tea is the cheapest thing you can drink. oil may be $70 a barrel - but vending machine Cokes are $450 a barrel! I don't even think I could do the math on a Starbucks latte! don't worry - we'll see $55 a barrel oil before we see $105 a barrel. In terms of inflation adjusted dollars, gas is the same now as in 1981 and we survived. (but gasoline TAXES are higher than in '81... grrr!) Carl
  21. Often, you can find STI owners (maybe WRX too) that want to do full trunk swaps - make sure you get the springs and lock swapped too. AND you might even find someone getting a carbon fiber hood that wants to sell the stock one! try listing your Want To Trade (WTT) or WTBs here and over at http://www.nasioc.com . (personally, I feel you'd be better off getting lighter rims (less rotating mass and less unsprung weight) and a lighter flywheel if you have a MT. Then maybe some stiffer - SLIGHTLY lower springs. Carl
  22. I'd make certain the CENTER diff gets a thourough inspection as well. Carl
