105
OMG!!! OK, tell, what would happen if you were, say, doing about 70 - steady, and floored it, as if to pass a motorhome and swing back in front of it to settle back down to 70. My wife's '03 OBW 4eat SLAMS down to 3rd after over revving slightly. In some parts of southern CO, you can set the cruise about 9 over. So, doing about 84 , going up an incline, I can see the TC unlock - that looks like its good for about 120 or rpm. That is smooth. But , if the load from the hill continues and the CC decides to downshift? man! it revs up to about 300-400 rpm OVER where it settles to AFTER IT SLAMS into 3rd. 2 different dealerships say thay can't duplicate it. And they never mentioned a firmware revision. It IS difficult to do around town here as it is barely perceptible at 65-70. I'm gonna try to take a tech for drive sometime. Occasionally, it's just annoying - one time, it nearly put me in another lane! The car will be getting a major service soon and we''ll see what it's like after the tranny fluid gets serviced. I will post if I ever discover anything else. Carl
Assuming the offset keeps the centerline true (most likely) and the tires don't 'bulge' more - its only 5 mm (1/2 the difference). Do you have suspension mods or increased neg. canber or something? If not - should be good to go! If you're not keeping the old rims - sell them nect fall - there will be dozens of people looking for rims for snow tires. Carl
It appears I was wrong and those tires look right for 15" ! I say go for it! Carl At first glance it appears your odometer/speedometer would be off. Try going to www.tirerack.com and , after drilling through to rim choices for your 90 leg, choose to 'plus 1' size it and see what the recommended tire size is. unless of course someone here has done it! Carl
Could someone, carefully and safely, pace the car while listening at each corner and perhaps hear something? Or could you roll down the windows and drive near a wall/fence and listen for anything odd? After driving for some distance, try feeling of the wheels and comparing the temps all around. In case there's a sticking caliper, one wheel might be warmer. I dunno Carl
gas pedal huh? odd Any general vibration such that a passenger could hear or feel? Any odd sensations when making low speed tight turns as in parking? brake pedal feel OK when braking? I suppose something causing engine vibration could be transmitted through the throttle cable. maybe bad motor mount? I dunno Carl
If it's a sweet, toasted marshmallow smell it could be a coolant leak. Sometimes a CV boot could split or get cut and throw grease on the exhaust. Sometimes a piece of plastic or something could get on the exhaust. Some folks get mice living in their cars! Definitely look around under the car. Of course , it could be mold in the A/C system - maybe the drain for the evaporater is clogged. If there is no fluids dripping on the exhaust, I'd try an A/C specialist shop. Carl
Take a torque wrench with you and double check the lug nuts between a coupla runs to make sure the wheels don't loosen up. Try to either have an air tank and a gauge with you or, at least, boost the tire pressure. How much? maybe someone can give you agood starting point - I ran 38 up front and 36 in the rear on my WRX. Take out any potential flying objects/xtra weight in the car too. Keep the shiny side up and greasy side down! have fun! Carl
Could be the ECU is still making some changes - one tank wouldn't be a trend. Several maybe. Does it smell like formaldehyde? That's one of the 'new' emissions that occurs from ethanol - no one yet knows what that will do to the environment. I also sem to recall that ethanol will increase NOxs somewhat. Maybe try an ECU reset and track a few tankfuls. It does seem counterintuitive but hey - better mileage is a cool thing! Carl
I'd need a portable, stereo, digital, recording device. Hmm, if I can borrow a digital camcorder, do they have an audio jack that will upload just the audio on playback? I've never examined one. Or a laptop with a microphone and sound card right? Hmmm.... actually, this is a job for my BIL - he's a bigwig at Uniden and I know he has a laptop. I'm emailing him right now. Carl
Gott im Himmel! Forget about recording my car - let's hear about your new ride! So, when does the 'happy event' occur? Trading in the old horse? Did you come into an inheritance? what? Just exactly what prompted this? (actually, I'm also trying to deflect your question from the fact I am technologically challenged as to presenting a recording of my car. Hmmm... maybe my middle daughter's boyfriend could help me.... ) good news on your intended purchase! Carl
I don't think I could trust any fluid not knowing the extent of the flooding. Brake fluid LOVES water - though the reservoir is far from the ground. After you cleaned the IAC - did you clear the ECU? might try that. Pretty much, after ANY emissions or aur/fuel components are altered you should do that. If there's a vent on top of the diff/tranny, exposure to cool water can cause those units to suck water in I think. I dunno. so cool that it's doing so well, good work. Carl
I dunno exactly what the throttle body setup is like, even though my wife has an '03 - never had to dive into it like you are. There was a thread a few months back about the IAC - it evidently is easy to screw up. Try the 'search' function. If the car never becomes reliable, it might make a good 'parts' car. Just clean, refurb,inspect anything that comes off of it before transplanting! Carl
