105
I pulled the factory oil outta my '06 WRX at 2200. My wife's OBW I think git changed at about 1600. I think, if you look around at the schedules at www.cars101.com , they show 3K for the initial change and 7500 after that UNLESS severe service is encountered. Since the rings may not seal well in a brand new engine, the original oil will lilkely contain more dissolved combustion byproducts from blowby. It will likely have the highest readings of other stuff (metals, silicon,etc.) as any oil analysis done for the next 100,000 miles . you might enjoy reading more about oil at www.bobistheoilguy.com .
Yep - toe. Likely aggressive driving as well. If you continue to drive agressively, try a pound or 2 more pressure and increase negative camber - then set the toe as said, near 0. There's some good reading at www.nasioc.com in the 'sticky' or threads of note in the steering suspension forum. Plus, sometimes tires are made poorly - but most name brands are quite good nowadays. Manufacturers have been forced to reduce the use of VOCs and I've heard rumors it has led to increased likelihood of tread seperation as tires age - I dunno.
spotted this on Usenet - just FYI news://news.dallas.sbcglobal.net:119/43e5e33e$0$6963$ed2619ec@ptn-nntp-reader02.plus.net or go to alt.autos.subaru and search for recent post ' Justy ' by grannieannie. this is the text; >>> Does anyone want a Subaru Justy J Series 1991/92 owner's manual before I throw it out? <<<< Annie
Thanx. It's tatse thing and a lot of folks don't care for white on white but I just didn't want gold or chrome and I felt anthracite would be to dark - I dunno. I DO think - for some reason - they would look out of place on a sedan. If you dig around at the following link, you'll see me and the wagon in action; http://www.hart-photography.com/2006/apex2006.htm
My fear is that PROPER diagnosis may not be possible with suggestions from a forum. And your limited funds may be better spent on a mechanic than throwing parts at the car. One thought, does your car have a K&N type oiled filter oiled intake air filter? They can kill MAF sensors. So, even if the recall was properly done, the new MAF may have been compromised by the oiled air filter.
use 'D' unless you have a need to lock in a lower gear or other unusual circumstances. You could always order a manual - try Jamie at www.subarugenuineparts.com also, look around at www.cars101.com Definetly investigate the coolant smell. Could be a simple as a bad radiator cap. welcome to the boards!
There's a front sensor too. Though the CEL you're getting might not indictae them. There is a scope or other test a tech can do. An hours worth of driving might be enough time for an excessively lean OR rich condition to make the cat conv block exhaust flow - maybe. (anyone else have more on this?) good luck
I think it may be time to investigate some of Setright's suggestions about the fuel system. Including the injectors. How many miles on this car? Wonder if the O2 sensor's been changed or the cat converter tested? Your car only has a 'bank one' (even though its a flat four - OBDII considers it a single bank 4 cyl) and there is evidently some weird air/fuel issue. It may be worthwhile also removing the covers to confirm a camshaft hasn't jumped a tooth on the timing belt. While it's idling, hold a strip of paper to the tailpipe, if it sucks the paper back in, you may have slipped time or have a broken valve. good luck Carl
