1 Lucky Texan
    105
  1. Based on what I've read, the above advice is right on. The only thing I have to offer, is there ARE things that will make the car handle better. You just need to abandon any thoughts of drag racing, and concentrate on the twisty or the off-road stuff. AutoX or RallyX is where you COULD have some racing fun. A nice combination of improvement comes with lighter wheels. Less unsprung mass, less total mass and less rotational mass - along with better looks! You will likely feel the difference in acceleration if they are really light. If you didn't mind the speedo-odometer being off, you could get more down low grunt with smaller diameter tires. Highway travel will mean higher RPMs and likely worse mileage though.
  2. If you didn't reset the ECU after that work, I'd recommend it. Disconnect neg batt term , step on brake pedal, reconnect batt after 30 minutes or so. Start car. If problem persists, retrace/recheck all hoses from intake/throttle body. Can you 'feel' cyl 4 injector firing? Got spark at cyl 4?
  3. In all fairness, the 'icon' Subaru uses for the 'single-wipe-per-pull-... mist...-function' is THE SAME as the symbol used to squirt washer fluid. You're not the first person to think something was broken. Even the manual is a little confusing.
  4. No problem - be sure to post some pics afterwards so we can see how slammed your ride is!
  5. If no one here has any help for you, check the appropriate forum at www.nasioc.com .There may even be some FAQs or 'sticky' threads on the issue. also, http://www.subarureview.com/suspension.php?PHPSESSID=d95940d8b8e7c0218bc1aff7242a1708 might be a good place to check. 2 inch is a little aggressive so doing some research about rubbing issues before you purchase is a good idea.
  6. Someone will probably know how to give you a link to that info. But while you're waiting - try lowering the window, placing a hand on the inside 'tweeter' area of the triangle, and your other hand on the outer mirror area and just 'squishing' them together. It may help for a few weeks or months. Try to push on the door itself and not the window when you close the car door on a regular basis.
  7. get a 6 pack or whatever of filters and washers from a discount dealership online (http://www.subarugenuineparts.com) and some Rhino ramps if you need a little xtra clearance to slide under the car. here's some good info; http://forums.nasioc.com/forums/showthread.php?s=&threadid=499177
  8. easier to find a 2 liter from a WRX or, if you're lucky, an STi I have only read about swaps like this. If no one here steps up with real world advice - try digging around over at http://www.nasioc.com those guys are big into modding and tuning.
  9. This is a good question. USUALLY, due to slight drag on the caliper rods I guess, the inside (with the piston) wears a little faster - so I would put it there. BUT, on the last car I did(dodge avenger), the squeeler pad was not interchangeable with the other side and it HAD to go on the outside. Seemed like a bad engineering choice to me. I dunno
  10. https://www.subarugenuineparts.com/product_info.php?cPath=32_36&products_id=118 http://www.etrailer.com/products.asp?category=hitch&year=2000&make=Subaru&model=Legacy&t1=&h=e&style=Outback+Wagon&ob=
  11. Limited, and some of the following have downsides associated with them or are otherwise controversial - listed in the order I think I would do them; Lighter alloy wheels (multiple benefits) 'snorkusectomy' lighter flywheel if manual tranny (but stay over 10 lbs or so) lighter (probably not underdriven) pulley set if auto tranny perhaps free-er flowing exhaust (though you may lose torque down low in exchange for a little high-rev HP) there MAY be some cams/internals available but at that point you may as well swap in a 2 liter turbo. A lot depends on what you want to do with the car. If you want to pull harder from the line, you could even get smaller diameter tires - though your speedometer/odometer will be wrong and highway mileage would likely suffer. just my $0.02
  12. If you mean drilled as in not original, I'd try putting some tape over it and see if the noise goes away. It could be a normal hole for water drainage or something if its factory original. I dunno.
  13. Check the airbox - it's kinda easy to not clip the bottom of it back in place well - causing an air leak and noise. Also, is there a difference between the noise based on whether the A/C or defroster is on? maybe the a/c clutch bearing is going bad. just some guesses
  14. Legacy777 and the experiences of others seems to point to the fact that, when the torque bind symptom is elimintaed by inserting the fuse it at least confirms that the solenoid is working. I'd like to try to figure out if there is the possibility that, in the situation in this thread where the condition did NOT improve, means the C solenoid or its wiring/etc. could be bad. But, it may also mean that, if the fuse being inserted is supposed to close the valve, that gunk may be holding it open - and thus a flush of the tranny may be succesful. am I making sense? It just seems like we could put together a 'flow chart' for DIY attempted fixes or at least troubleshooting the problem.
  15. Nipper, if the C solenoid is prevented from sealing - either because its bad,-( is it 'normal open or NC?) - or the seat is blocked/leaking, does that place the center diff in full 50/50 or in FWD? Another way of asking; if the fuse is in place, applying a constant 12V to the C solenoid,(right?) is it forcing the valve closed or open?
  16. You could dig around here; http://www.ravensblade-impreza.com/modifications/brakes/brakes.html Also, the stock components are not that bad. Good compromise between noise, wear, fade and stopping ability. You could try an 'upgraded' semi-metallic. Almost any change could bring increased noise or increased rotor wear. I dunno
  17. I think it would be perfectly understandable to let them know how disappointed you are. Its OK to be emotional - just don't threaten anyone or get vulgar. Try to go through the conversation in you head a few times, try to think of all their responses. Be prepared for -"They all do that" at which point your response should be one of 2 staements; "Then they are all broken and need to be repaired and you can start with mine!" or "Give me the keys to THAT one - you wanna ride a long?" also, I've gotten better service by using a phrase like "How would feel if you were in my postion?" or "If you were me, what would your next step be?" Also, be prepared to go up 3 levels in management, and let them know you'll be happy to camp out in the boss's office until he shows up. Don't be afraid to ask for the owner/manager to resolve your problem - that's one of their main functions! Big problems! Sometimes it's good to go right before lunchtime or quitting time. DO NOT threaten to sue. Most folks who threaten legal action never carry it out and other folks know it. If you feel you need to, calmly ask for a legal contact number or say "I really don't think we need to involve a 3rd party for this problem, do you?" I think the new cars all have variable assist stering, maybe some speed sensor or something is telling you car it's at highway speed all the time and it is stuck on minimum assist. I dunno
  18. The CENTER diff is only going to attempt to transfer torque when there is slip detected on one AXLE versus the other. There probably istn't enough difference when turning to do much to activate the center diff. Again, this is under normal conditions. (and others here may be able to fill in some details) .In other words, when you turn right, the left front and the left rear wheels turn faster than the right side wheels (the front and rear diffs take care of this so there is no scrubbing or dragging) BUT the front drive shaft and the rear drive shaft are turning about the same rate so there is no slippage detected to cause the CENTER diff to shift any torque. Again, under ideal conditions. (my head hurts)
  19. Nipper, you say '98 is when the aluminum part (didn't know it was a seat for the duty sol C) changed to steel? That's good to know. I usually can't remember the details like that.
  20. Zephyr - you and others reading this might enjoy these 2 links; http://www.archive.org/details/Aroundth1937 http://auto.howstuffworks.com/differential.htm fyi
  21. You still have diffs on each axle. When something is broken or wrong, you can get weird behavior. Subaru's sensitivity is why, when things are normal, the system works so well. But it can't 'know' the difference between a slipping wheel, or one that is rotating faster because it is undersized. And if something is broken - can't expect it to compensate for that.
  22. Keep in mind that dealerships probably average $70-$80 an hour for labor. And they likely are charging a markup on parts. It's quite likely you could put on new rotors and pads yourself and not spend $100 (I just did this on the front of a Dodge Avenger for $45) Maybe you can find a buddy next time to walk you through it in exchange for a coupla beers. Or find an independent garage - they may have a labor rate $20-$30 less than the dealership.
