105
I hate to suggest shortcuts but - depending on how long the boot has been split, you can drive for THOUSANDS of miles before it actually breaks. I used to put pads on all the time without turning rotors. I think a combination of DIY and an indie mech is called for here, pribably get the price down to a third.
I'm sure there's no end to additional stuff but I think you should consider a thermostat and radiator cap. Possibly run a bottle of Techron through a tank too if you don't already have it in a yearly or semi-annual schedule. And do a throrough inspection that would include brake pads and wipers(especially if it's the wet season where you live). fyi
OK - got NO IDEA if this would relate to your problem. We once had Colt Vista wagon (I know, I know...) and the control rod from the solenoid was adjusted TOO tight. When it was switch locked it would load up the rod and when the solenoid was inactivted it would actually 'bounce' back enough to unlock the hatch. Using the key though always worked. I took the panel off and saw what was happening, made an adjustment and never had another problem. I doubt this is helpful but hey - what did it cost ya?
Thanx suby7. Just got a great email response from Wayne Chin - he has a nice OBS related site. For info. to backup suby7's link, try; http://www.druidhillroad.com/koni/ Also, Wayne says the AGX part numbers shown here; http://www.coximport.com/agx/apps.html WILL work for front and rear of the '93-'01 OBS. The KYB catalog I downloaded last night only shows fronts? Maybe an email to KYB is in order? Wayne's site is at; http://wac.addr.com/auto/obs/obs.html
You can always ask. Perhaps they could throw in some type of powertrain warranty. Maybe they'd offer to replace them at a reduced price?(you pay for parts and 1/2 labor or something) Or just make your offer low enough to cover the repair and if they balk at the number you look them square in the face and say; "Knowing how often the HGs fail in these cars, what would YOU do in my position?" See what they say. You need to be comfortable with your purchase. If you can't be, shop somewhere else or for something different.
Thanx! Um - the Impreza Outback Sport seems to be the chassis with the least attention from companies making aftermarket perf. equip. Much information is confusing. I have read about Eibach not lowering much - but the real issue is more like, are springs and struts sold for Imprezas REALLY appropriate for the OBS? I don't even have the car yet, but they are a little more common in my area than the RS, (I may drive down to Temple to look at a '00 MT OBS). Does the USDM OBS go by a different name in Europe? I will investigate H&R - perhaps putting them on some KYB GR2s is good enough for my purposes. The IDEA of the AGX adjustables is appealing - just don't know I'd really use it that much. thanx
Just guessing, but one reason you may be confusing yourself is that , if like my '03 OBW, you have a hi-lo position switch, the low position runs the back/seat in series, the high position runs them in parallel. If it is 2 position and neither element heats in 'lo' then most likely an element is open. But if they work in 'lo' and you lose one on 'hi' could be the switch or - I dunno - a fuse somewhere? If yours is single position I dunno, try to compare the working seat to the non-working one. sounds kinda tricky - good luck
I doubt that I'd have any clue either but i will offer a suggestion or 2 based on what I've read. Sometimes a bad/dirty PCV valve/hose can cause pressure to build in the crankcase and camcovers. Any small seepage will leak more due to the pressure. Sending in an oil sample for analysis might help tell the ring conditions. They would allow more blowby if worn and the oil would have more fuel and combustion byproducts than normal. But starting with normal compression and 'leak down' tests would likely help as much. You don't mention leaks or seepage. Do a search on these forums and you will find the common seals and oil pump backplate leaks mentioned. If the cars has only a few spots, but from different areas under the vehicle, you most likely have a leak only when the oil is pressured up and during driving it is being sprayed back onto the undercarriage to drip randomly when you stop. I had this problem 3 times on 2 cars (non-soobs) due to leaking oil pressure senders. You also didn't mention anything about the cars prior service history. perhaps it was abused? If indeed you have bad valve seals or rings, do use a slightly higher viscosity oil but DO NOT think it can go longer between changes because you have to 'top up' frequently. It will become contaminated with fuel and need to be drained.
Your nose and looking for damp spots around fuel lines are your best bets. Seems like a fairly new car to have a serious issue. Could be the vapor recovery canister/purge valve. Especially if 'overfilling' the gas tank is a common practice, I guess the canister can be saturated. Is there any recent service or damage history? CEL?
Vote your choices...
1 Lucky Texan replied to 1 Lucky Texan's topic in Meet n' Greet. Your USMB Welcome Center
down to 6! Vote now for the final winner! poll at Off Topic is open! fyi -
Need your vote!
1 Lucky Texan replied to 1 Lucky Texan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
voting from FUN list of 6 for final winner over at the OT forum. check it out! fyi -
My mistake, sorry, - when I had a B&W darkroom we had some type of anti-static brush dealie for dusting off negatives and optics with a polonium strip in it. I got confused. Must be the radiation exposure. Didn't know about the half-life - wonder what they thought the advatage was for spark plugs? Or were they just unable to eliminate polonium from some alloy or coating on the plug? Radon is one reason why, it MAY be beneficial to occasionally hang upside-down. It is a very dense gas that emits alpha particles and can potentially be inhaled in a basement area in some parts of the country or while showering.
IIRC polonium is an alpha emitter and, while your lungs definitely don't need dust from an alpha emitter in them, that shouldn't be a big problem for a spark plug. A couple shhets of paper will stop alpha particles. I don't know why they think they NEEDED polonium, but it wouldn't particulary frighten me. Of course, a lot of smoke detectors have a polonium strip in them. If you have a survey meter, test Coleman lantern mantles sometime.
