105
Kia Sephia Sporty
1 Lucky Texan replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
wow, I dunno if I'd have half the self confidence to attempt that. hat off to you Sir! -
since there seems to be a difference idle vs cruise rpms and cold vs warm, kinda thinking live data would help a lot. check sengine temp readings and fuel trims at idle vs higher rpms, etc. NGK plugs with proper gap? plug wires in good shape? try spraying them and the coil with water from a spray bottle. no oil on plug boots?
New Member intro
1 Lucky Texan replied to sharksfan95648's topic in Meet n' Greet. Your USMB Welcome Center
if it was limited to just 2-3 traces and the components seem OK, might be worth trying some 22ga or w'ever wires patched in. It could work - at first. However, one has to wonder, with that severe a surge, what's the remaining lifespan of some of the components that have been 'stressed'.
I feel it's worth checking for a slight timing belt slip - bring the marks on the pulleys around to belt install position, and do a tooth count. You can find tooth counts on line for different Subaru engines.
Best source for axles?
1 Lucky Texan replied to Ionstorm66's topic in Old Gen.: 80's GL/DL/XT/Loyales...
on many outer CVJ (Rzeppa joints) there is a snap ring on the end of the axle you remove. Then there can be some hammering involved if the inner part is stuck on the axle. -
also, batteries in Oregon would last longer than batteries where I live but, you battery, if original, was certainly not 'young'. The original issue could have been caused by a weak battery, with a partially sulfated cell or ....? I have had spurious codes set by failing batteries on 3 occasions in 2 different cars. I have read elsewhere that oil lelvel sensors have been known to fail such that the light comes on when levels are only a few ounces down - increased sensitivity. Check subaruoutback.com for posts about oil level sensor. I also think it's 'possible' that, in order to satisfy your request to see a damaged wire, the dealership grabbed the first wire they could find, cut it, and displayed it. Doesn't mean they lied necessarily about the actual problem, but maybe your 'real' part/wiring had already been thrown in the bin andno one wanted to dig for it. just an idea.
just a coupla comments. A lot of rodents have urine that will glow under UV I think. Not sure which rodents ot what wavelength UV - worth researching .... Rodents MUST chew due to incisors that never stop growing. rodents are able to get into really cozy spots. If ALL the cuts are to wiring with 'clear and easy' access to a persons arm/hand equipped with diagonal cutters....suspicious.
Struts
1 Lucky Texan replied to Sherman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
^^^ yeah, if you tell us what your goal/desire is for the car - there are several folks here who could help you modify it. -
Struts
how many miles on the 05's struts? I'd put new on for the trouble.
