105
ATF spec
1 Lucky Texan replied to patcal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Setrights advice is correct. There are severe incompatibilities betwenn some ATF fluids. I got that education the hard way many years ago. Be careful. -
Did you feel it in the steering wheel? Did it seem 'up and down' side to side' - anyqualifiers might help. Any pulling/drifting off track? The noise - was it high pitched and tinny of low pitched and knocy/clunky (usually the low pitched noises are trouble). We need some hypnotic regression to bring your suppressed memory to the surface.....you're getting sleepy...sslleeeeeeeppyyyyyy.............
One exception to avoiding 3rd party ext.warr. might be like GEICO. Pretty big company. I haven't decided to pick it up, mostly because of the 'overlap' with the already fairly generous Subaru standard warranty. On my '03 OBW they quoted $78 a year to 100,000 miles - NO TIME LIMIT. So if it takes 14 years to get to 100,000 I'll have coverage. It's exclusionary, which is good, anything not specifically on the list is covered. You can have it serviced at any certified shop(? - that probably means you can't diy it) You can drop it anytime and just stop paying the $78/yr. But, it's $250 deductible and you must add it before 11mos./11K or the end of the car's model year. But, if a drivetrain component goes out in - say - 2.9 years that costs $1000 to repair, you will have paid close to $230 for somthing covered by Subaru right? If the same thing happens at 3.1 years, you will have paid the $230 plus shelling out the $250 ded. It does seem that for someone buying a car that will not see high mileage, has a poor standard warranty and is expensive to repair this would be ideal. I just think keeping a little xtra in the bank for the car is just as good. What do you guys think?
HERE'S 2 WAGs (wild @ss guesses); 1. The fuse you used is too small or bad(20 amp required I think?) 2. The failure mode for the solenoid is 'full transfer' and is not being disabled by the fuse.(seems unlikely). I'd confirm you have a good 20 amp (check the manual for proper size) fuse in there. An Autozone employee could probably check it with an ohmmeter. thanx for replying and good luck.
Short term - start with about 2psi over the 'door post' recommendation - adjust for ride/handling/load - BUT monitor tire wear closely. As a general rule - for the same vehicle weight, going to larger tires means a bigger 'patch' on the road and lower pressures. But there are a lot of variables like sidewall stiffness, centrifugal forces at high speed, changing loads etc. good luck
Rust? Nah they don't usually rust in Texas - they don't survive the hail and Tornadoes long enough to rust! (LOL) But I suppose a car could show up that had spent time elsewhere. I missed cheking out a MT Impreza. I may go look at one after work today that's AT - more to get an idea of what I'm looking for. I'm not opposed to getting an AT but am not in a hurry either. Are the ATs from the mid-90s troublesome? thanx guys for trying to educate me.
That age car could have a problem almost anywhere. Also, don't assume that whatever(waht was it?) they fixed the first time was done well/correctly either. Is the smell stronger in one area than another? Is there a 'wet/black' or shiny clean spot somewhere surrounded by dirt? Have you placed cardboard or newspaper under the vehicle and let it idle for a awhile?
