105
Well, now that the site is back up of course I'm at home again and the document is at work. It's a SAE technical paper, number 890-somethin and it seems the text and drawing on page 6 indicate oil coling nozzles are on the turbo only. They are timed with the journal holes to reduce big fluctuations in oil pressure. sorry for any confusion.
ATF spec
1 Lucky Texan replied to patcal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'm glad it worked out OK. btw - the 'original' Dexron (dexron 1 we'd call it now I suppose) contained about 2% WHALE OIL! BTW- is there a 'synthetic' or other 'high tech' version of ATF fluids? -
I'm such a noob that when I signed on to the forum one question I asked was about general engine layou/design info/exploded drawings. The site I was sent ot had a PDF download of some FHI technical 'bragging' that included a lot of drawings and design philosophy stuff. It does show the piston cooling jets. This document was from '89 and refered mostly to the 1.8,2.0 turbo and 2.2l (I think that's right - don't have it here) and mentions the DOHC and SOHC engines as well. Quite possible the drawing I saw was not generic and only one engine has the jets, but they were there back then.
ATF spec
Setrights advice is correct. There are severe incompatibilities betwenn some ATF fluids. I got that education the hard way many years ago. Be careful. -
Did you feel it in the steering wheel? Did it seem 'up and down' side to side' - anyqualifiers might help. Any pulling/drifting off track? The noise - was it high pitched and tinny of low pitched and knocy/clunky (usually the low pitched noises are trouble). We need some hypnotic regression to bring your suppressed memory to the surface.....you're getting sleepy...sslleeeeeeeppyyyyyy.............
One exception to avoiding 3rd party ext.warr. might be like GEICO. Pretty big company. I haven't decided to pick it up, mostly because of the 'overlap' with the already fairly generous Subaru standard warranty. On my '03 OBW they quoted $78 a year to 100,000 miles - NO TIME LIMIT. So if it takes 14 years to get to 100,000 I'll have coverage. It's exclusionary, which is good, anything not specifically on the list is covered. You can have it serviced at any certified shop(? - that probably means you can't diy it) You can drop it anytime and just stop paying the $78/yr. But, it's $250 deductible and you must add it before 11mos./11K or the end of the car's model year. But, if a drivetrain component goes out in - say - 2.9 years that costs $1000 to repair, you will have paid close to $230 for somthing covered by Subaru right? If the same thing happens at 3.1 years, you will have paid the $230 plus shelling out the $250 ded. It does seem that for someone buying a car that will not see high mileage, has a poor standard warranty and is expensive to repair this would be ideal. I just think keeping a little xtra in the bank for the car is just as good. What do you guys think?
HERE'S 2 WAGs (wild @ss guesses); 1. The fuse you used is too small or bad(20 amp required I think?) 2. The failure mode for the solenoid is 'full transfer' and is not being disabled by the fuse.(seems unlikely). I'd confirm you have a good 20 amp (check the manual for proper size) fuse in there. An Autozone employee could probably check it with an ohmmeter. thanx for replying and good luck.
