'96 Outback Noise
1 Lucky Texan replied to swhatcher's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's a WAG (wild *ss guess). Check for a torn inner or outer boot. It may be ripped in such a way that it flapps around at speed but resumes a 'normal' appearance stationary. Actually push,squeeze, pull on them. There would probably be a lot of grease thrown around under there and since you didn't mention it I'm probably wrong. Coulde you have a belt that's ripped or has cord hanging off it? good luck and let us know OK? Carl 1 Lucky Texan
OBW trip report - very long
1 Lucky Texan replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStill no CEL returning and car runs fine. I guess no one else has noticed the same AT or CC issues huh? Carl 1 Lucky Texan
EJ22 timing belt marks???!!!
If its DOHC and his cam timing was off when he cranked, the funny sounds he heard COULD have been valves crashing into each other. The farther off from ideal timing the more likely this was to occur. He needs to quantify how far off he was and pulling the heads may be in order. Carl 1 Lucky Texan
FWD Fuse Holder
1 Lucky Texan replied to Phillip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK - AT Subarus need the FWD fuse inserted if a spare (donut or significantly different size) is used right? Does it matter which corner gets the spare? Why aren't left/right diffs. damaged? Carl 1 Lucky Texan
Going on a trip, What to check?!?
1 Lucky Texan replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt so happens my youngest had her PPC with her on my recent trip (see OBW trip report - very long) and it would hit cells fine but occasionally showed a roaming charge. I assume it just 'charges' more minutes - like maybe 3:1 or something? Anyway - it will work. Do be sure to keep a mental note of nearby exits/landmarks. I don't think it's easy to triangulate your position yet. You will need to give general directions to 911 in an emergency. Also, flatbed tows only for AWD Soobs OK? Carl 1 Lucky Texan
Welcome to The new board
1 Lucky Texan replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanx Josh, that's what I needed I guess. Carl 1 Lucky Texan
1 Lucky Texan replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think there was an event over at TMS right before I bought my OBW and joined the board. maybe Legacy777 said something about it? Don't recall if it was Soob specific or a SCCA thing or what. I'm seeing more now that I own one (like getting a donorcycle or a ragtop - you start seeing whatever your new ride is) even saw a Baja at the grocery store, but it can't compare to CO! Carl 1 Lucky Texan
1 Lucky Texan replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow Sam, a very succinct description that sounds a LOT like what I encountered - just a different engine. I wonder if the tranny 'algorithms' can be reflashed or something. I'm a flatlander and I'm annoyed by this, seems like all those mountain folks with Subies would be outraged at the way this thing behaves on grades. My '96 Windstar's CC was WAY ahead of the Subie's. I could even pop the paddle and accel or decel 1mph for each pop. FHI is behind the curve on this issue. But thats just annoying - the crazy downshifting/jerking at high speed is a problem. Anyone else seen this? Carl 1 Lucky Texan
1 Lucky Texan replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wonder if the date and the manila colored folder/paper dealie could be moved to the TOP of the left margin? You can't tell when it's a newer post on long posts til the bottom. Or maybe I have an option to change that? I'm still a little confused by all the choices. Carl 1 Lucky Texan
1 Lucky Texan replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo - has anyone else encountered the tranny or cruise control issues I outlined above? I wonder if some different (synthetic?) AT fluid would help? Carl 1 Lucky Texan
