105
there is a special spray cleaner for MAFs, you could try cleaning it first, there are delicate wires and maybe the Int. Air. temp sensor inside. even a tiny peice of a leaf can throw it off. there have been some MAFs with poor construction inside (intermittent solder connections) and a new sensor may be a good idea.
Welcome back and my life has become a little topsy-turvy recently but I recognize that many people are really suffering. hang in there. There's a 'far side' to all problems - you just have to last 'through' the problem..
you can connect diagnostic wire under the dash and force the solenoids to cycle, at least you'd know it can operate. if topping-off when fueling has been mostly avoided, the carbon canister is unlikey to be flooded so, 'drain' hose or valve is the problem, or the tank valves I think. On some systems, the 'drain' is a 2-way deal. Under normal circumstances, it lets outside air in to compensate for the lower tank volume as fuel is used-up. I guess it also allows air in when the purge valve opens? During fueling, it allows fume-laden air to enter the carbon canister and fume-free air (after the carbon adsorbs the fumes) to escape. it's complicated and there can be some differences between year models. Others may explain it better.
disconnecting hoses is one way to troubleshoot the issue. Could be the 'drain' valve is stuck or it's hose plugged with spider/wasp nest or ??? the worst case, the evap valves built in the top of the tank are stuck. the evap system changes from model year to model year and you need to find the diagram for your model. has the car sat unused for a long period of time or has it regularly been 'topped-off' when filled with fuel in the past?
Better valve cover grommets?
1 Lucky Texan replied to Ionstorm66's topic in Old Gen.: 80's GL/DL/XT/Loyales...
...and do not overtorque those shoulder bolts, they WILL snap. -
Throttle Body Cleaning
1 Lucky Texan replied to Bobinbigsky's topic in NA Fuel Injection Engine Tech
kinda dodging the direct question to mention that SeaFoam has a spray can with a special u-turn nozzle designed to use in-car. Look for videos how to use it. -
Shipping car from New Mexico to LA! SOS
1 Lucky Texan replied to KevinHartman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think I recall reading the user @GeneralDisorder has shipped a few cars. maybe he has a company to recommend? -
Best source for axles?
I wish we could find an NTN discounter..... -
Small coolant leak.
you could try the Subaru Coolant Conditioner (rebranded Holt's Radweld) - 1 bottle only, installed per directions ONLY. -
local tuner gets new FEQ brand 'HD' (which only gets you better rubber boot at the wheel end 'I THINK') from some distributer called Worldpac, but I have seen them offered at Amazon, etc. I think. Might be worth running backwards from the FEQ website - maybe find the part number for the HD axle for the car in question, then find a retailer...? Does anyone still get axles from Raxles ? VW guys seem to like them. -
Hello everyone!
1 Lucky Texan replied to gunslinger61's topic in Meet n' Greet. Your USMB Welcome Center
hmmmm... not sure about this but, just chiming in to mention I have read of the Aussies building sand rails with soob engines. they may have some interesting adapters or components. -
If the system is working correctly, it is 'self adjusting' . This is a very common failure on 15+ year old cars. Many people have fixed this. Of course, it's possible to have more than one problem, it's possible to get a bad new part, but, it is not anything special, expensive or requiring a visit to a dealer.
I think for an enthusiast with some time/money on their hands, or someone with a race whip, there may be some utility in experimenting with gear lubes - maybe moreso if you live in the SW or extreme north, further tailoring the lube chosen for extreme temps. but, the OEM lube (Extra-S ? made by Idemitsu I think) or a name brand non-synth lube probably works fine for most people. If you have a leaky, or older car and no money to spend, there is a synth-BLEND at walmart (supertech ?) that folks feel is a good value. Local tuner shop (the guys that fixed my trans) use Amsoil Severe Gear 75W90 . It's still in there. feels OK to me. BUT, I also had to rebuild my shifter and since putting in new poly bushings, kinda have the itch to try something new. But, not driving the car much right now - lost my job. I also have a feeling the trans prefer quicker shifting, seems like I get more balking if I'm slow about shifting - could be a lots of factors really. if you want to go down a rabbit hole - try this link; https://forums.nasioc.com/forums/showthread.php?t=920674
I have had 'spurious' codes thrown 3 times on my 2 soobs, (even put my WRX into 'limp' mode) bad batteries everytime but, I suppose other issues like charging system or poor grounds or 'dirty' connections, etc. could cause the same type of problem. And often codes are thrown due to issues unrelated to the 'official' definiton/description of the code's involved. That is, just because a rear O2 sensor has 'catalytic converter efficiency' in it's description, doesn't necessarily mean the catalytic converter is bad.
If someone put synthetic lube in that 5spd you dove, that could explain some 'balking' when shifting. Because the trans and it's synchros share housing/fluid with the front diff, non-synth GL-5 is usually best. Full synth causes the synchros to be too fast or something...MANY people tinker around with finding their favorite 5spd lube. There's a huge thread devoted to the issue at NASIOC.
one or 2 people have swapped-in a 5spd or, better, a Legacy Spec B 6spd into an H6. the H6's xtra power would probably be a death knell for the 5spd. If you're just on flat-ish/dry-ish gravel/dirt, 5spd 4cyl probably OK. others here will have actual off-road experience for your questions. I mostly wanted to warn you about 5spds - they have a but of a poor reputation. Certainly more-so among WRX owners - they start tuning the car and then complain when the clutch or trans fails. I paid $2000 to fix my trans(2nd gear is cut onto the main shaft w'ever), wish I could have afforded to just get a 6spd put in but, alas, I couldn't justify it at the time, plus all the other internals looked great (the tech said) and - under 70k miles too.
