105
dunno really, read that the early ones have a reputation for being underpowered. Maybe check cars101.com for features?
Right pull persisting after alignment+tires
1 Lucky Texan replied to Ionstorm66's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sometimes, brake lines can act like a check valve, maybe the pressure bleeds-off after a while but 'locks' immediately after brake use for sometime. guys, could this be a broken axle? freewheeling while the good one does all the pulling? (but I still dunno what vehicle this is - might not be possible) -
some folks I've read used Marvel Mystery oil to 'clean out' stuck hydraulic lifters. just using a synthetic - cheap walmart or w'ever - 'could' eventually clean out old gunk. One of the reasons synthetic looks very dark on oil changes is because it keeps varnish in suspension better than conventioal oil. It can clean, then keep things cleaner. just some ideas thoughts on the issue.
XT6 Transmision onto 3.0R engine
1 Lucky Texan replied to nazvwxt6's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have no power mods on my WRX and zippered 2nd gear smooth - under 75k miles(but, plenty of spirited driving and rev-matched decel). Many people have lost 3rd gear in the 5 speeds.....I've read the case is weak/flexes ? that said, I think the 06-up 5spds got a little better 1st gear synchro.... -
if it seems too big, look at a Forester - or maybe Crosstrek ? My wife is itching to buy herself a new car - maybe a Mazda - but, even though we really have zero need for 3 cars, I REALLY don't want to sell either of my cars. The WRX makes no sense to keep other than I LOVE driving it, the Outback is starting to squeak groan somehwere in the rear so I know more rubber is going bad.... plus, It's harder for me to crawl around under them....Outback is needing quite a bit of refreshing, and the WRX I know is a ticking time bomb.....
Interchangeable Parts?
1 Lucky Texan replied to AA-Ron's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah, read 2-3 times of folks using WindoWeld to make/repair bushings - even 1 or 2 youtube vids on that I think. -
maybe use a 1.5 or even a 9v volt battery to see if you can force the gauge to change at all??? weird
- 6 replies
- engine coolant temperature sensor
- sending unit
- (and 8 more)
legacy spec B 6-speed would be awesome -
In one test I read, 50:50 acetone and ATF worked better than 3-4 fluids sold as penetrating oil !
is it better after a battery disconnect 'reset' ?
Ej22 l series vs 2005ish h6 outback off road
1 Lucky Texan replied to Raynman1989's topic in Off Road
Numbchux, from what I have read (no experience) sand can be challenging if you have the wrong tires or have too much tire pressure? -
I gave some very wild ideas on the other forum but here, I wonder if the 'dogbone'/pitch stop bushings could do that?
Intermittent Dead Battery
1 Lucky Texan replied to glsubby's topic in BRZ and its Sister the Scion FRS/Toyota GT86
you can use a multimeter to monitor 'dark current' while pulling fuse to pin-down the offending system. any work,wrecks, mods to the car before this began? (electronics plugged in, new head unit, dash cam or ???) -
+1 on starter/solenoid question above will that '97's fuel pump have enough output?
- 60 replies
- 6 cylinder
- subaru
- (and 8 more)
DANG! so awesome. is that a caster adjustment you modified? also, I don't see you using the 'alternate' hood prop in any of the pics. You can move it to the xtra hole on the piece on the pass side strut tower. I THINK on some older models, you also flip the rod over.....? I used it on my WRX when I pulled the TIC.
