105
try running with the gas cap off/loose? that might condemn or exonerate the evap system.
- 19 replies
running premium fuel? even so, you may need some octane booster.
- 19 replies
look on the right side of the rear engine bay, lower and further back than the ATF stick. No need to idle the car like for ATF. Just pull and check level. If you decide to drain/fill, wipe the metallic sludge from the drain plug magnet. Hopefully no 'pieces' are on there. I think you you need a T-70 Torx bit IIRC.
Fan Hit the Radiator but why/how?
1 Lucky Texan replied to Leebo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
drive thru very high water? it can flex blades forward.... -
Ej22 poor fuel consumption
1 Lucky Texan replied to Raynman1989's topic in Old Gen.: 80's GL/DL/XT/Loyales...
some folks have had knock sensors go bad with no code. bad temp sensor maybe could cause rich running with no code? maybe 'disturbed' exhaust system now has a little blockage somewhere? -
I just fixed my WRX's shifter for the same issue. You either need a new trunnion/shift u-joint, or new bushings in it. I put poly bushings in mine from TIC (Turn-In Concepts). I also upgraded the support rod front and rear bushings with Prothane parts. And I Upgraded the shift handle bushings. Found a youtube video that helped and had a thread here with suggestions from others. It was a fiddly process but I am glad I did it.
does it smell like diff fluid? maybe someone made a mistake and put diff oil in the trans?
Idle Stutter When Brake Pedal Is Pressed
1 Lucky Texan replied to G3.Spiffy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
electrical power demand also increases as the brake lights come on - maybe pull their fuse or their bulbs to troubleshoot that idea? -
well, you know what happened the last time the Germans and Japanese got together......
yeah, any reasonable repair that doesn't increase risk to other parts should be fine. Some folks run with naked belts but I probably wouldn't on any daily driver. If I had just a fun whip, I might not care. maybe JB weld a piece of a CD/DVD/Blueray disc over the hole?
- 3 replies
- 1
- engine
- timing belt
(and 1 more)
Tagged with:
yeah, IF it's cooler, it's subtle and certainly only a few degrees. No sign of leaks and seems like everything is good.
I briefly considered changing the stat but, it seems failure is quite rare and, though 14 years old, it has under 80 K miles. I'm comfortable with it until the next time I change fluid or am into the system for a repair. The know car is gonna need some tlc soon, I love driving it but I know it's going to need some stuff I will likely hire done. $$$, nervous about finding a shop to work on it that's nearby and trustworthy. Eh, maybe spend my stimulus money on it or first coupla Soc Sec checks next year lol! lets see; clutch, plugs, TGV delete, air cut block-off plates, killerB oil pickup,heavier rear sway bar, MC brace, TUNE! hah!
lower Dayco hose needed trimming, seems OK after 3 inches off 1 end, and about 3/4 inch from the other end. I was prepared for that, Gates was the same with a warning about cutting, but a review at Amazon seemed to indicate it still was kinked? Top Dayco seemed like a perfect fit and has nice protective sleeve on it. They were easy enough to slip on. I used Gates constant pressure clamps. They have some kind of stack of dished washers that act as springs? (I think?). They don't seem to crawl backwards as you tighten them either. Filled some thru the top hose, then rad and little turbo tank and put some xtra in the overflow. First run-up after that and it tried to overheat so I shut it down and let it sit overnight. Kinda expected there's be air. In the morning I added, dunno, maybe a 4th or 3rd of a gallon asit had pulled a lot in from the o'flow. Ran to temp, fans on, temp gauge good. Drove to work on Monday. Everything good today as well. I swear it's indicating lower temps. Probably changes slowly with age and the other one was getting less efficient? thanx for the help guys!
Gas shooting out the filler.
1 Lucky Texan replied to Ionstorm66's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what car model/year? -
had to use a coupla zipties to 'bolster' 2 of the plastic bosses that screws go thru for the fans. I dunno, I either cranked too hard or they may have already been cracked....anyway, seemed secure enough but the zipties might help in the long run? first long drive to my 'essential' job and the temp gauge was rock steady - could be my imagination but it might be indicating about 1/2 needle widht lower than before. I'll check for drips and probably inspect my work and the new rad a coupla more times before I get completely comfortable lol!
