2009 Forester won't turn over after engine swap
1 Lucky Texan replied to pblanton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcycle the fob a coupla times, maybe it thinks it's stolen or the battery was stolen?
- Got a visit from the airbag police....
Rear wiper reservoir clogged?
not sure about the overflowing.... I have used ice cubes , shaken vigorously, to clean the radiator overflow.
Craziness
1 Lucky Texan replied to machineit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpaging @GeneralDisorder
Power steering squeek.
1 Lucky Texan replied to cspurli2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDex II/III/VI ATF should be used. Valvoline MaxLife is what I used.
1 Lucky Texan replied to cspurli2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXair in the PS fluid quite likely. had to replace o-rings on suction hose adapters on both my soobs.
07 OBW 3.0 H6 Wagon- Engine Scraping/Rattling Noise
1 Lucky Texan replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany chance you could use a mechanic's stethoscope or even a dowel rod or long screwdriver to the ear to pin-down the location better? my first gut-feelings were serpentine belt idler/tensioner bearings, or possibly cracked flexplate.
Input on 2016 Outback
^^^good post, second the oil minor point but, easy for folks to overlook the cabin air filter.
Whine at right front wheel area
1 Lucky Texan replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it's like a squeal, could be the backing plate has trapped some debris against the rotor, or is dragging?
New Member (again..)
welcome back Dusty, there are folks here with ej22 swap experience. Someone will reply I'm sure - the recent virus issue may have some folks a bit distracted. try a search to read about swaps.
2001 Subaru Legacy L Wagon Battery Drain
1 Lucky Texan replied to potter2010's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX4 cyl or 6?
neat 1999 impreza
1 Lucky Texan replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWANT!!!
2005 Impreza OBS- source of oil leak
1 Lucky Texan replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsome older filters had bad crimps and would leak sometimes......r
still hunting the front end shake and lost as to where to go.
looks like hubs were done
could an observer in another car 'pacing' you perhaps see something? video the front corners, etc.
is it less noticeable on wet roads by any chance? or on gravel?
I edited my last post, el freddo is talking about center drive shaft I think?
EDITED; have half-shaft/CV axle nuts been torqued with wheels on the ground? FSM says not to do that - no weight on the wheels.
1996 opps 1998 2.2 imprezza timing belt install?
as a triple check, find the tooth count for your engine.
check hub/rotor/caliper temps with an infrared thermometer after a highway run. is the wobble in sync with tire roation - or, 'about' 4 times faster? if you lightly touch the brakes while wobbling, can you feel pulses in the brake pedal or, does it change the symptom? did this begine gradually or after some work on the car?
Steering rack question
Pretty sure my 06 WRX wagon got a faster ratio vs 05. Maybe the 05 Saabaru was ahead of the curve?????
Transmission, Engine, or All The Above?
1 Lucky Texan replied to CityLights's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXah, I guess that's right. I thought it was only VDC.
Yet another po303, po304 question
does it idle rough? if so, try a stream of propane from a handheld torch or some ether-start into the intake. If idle smooths-out, that may point to a fueling issue. check all grounds.
1 Lucky Texan replied to CityLights's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXone thing for certain, you must use the FWD fuse in the block under the hood if you mix tire sizes. Even very slight differences are very stressful on the drive train and it's usually the trans that suffers. so, use of the donut requires use of the FWD fuse. seriously. tires need to be the same size/brand/model and near each other in wear. that trans also needs OEM or compatible fluid. of course, check fluid level when idling.
is there oil on the plugs or their boots?
