105
Dipstick broken off in tranny
1 Lucky Texan replied to Espey16's topic in Old Gen.: 80's GL/DL/XT/Loyales...
OK, here is a stupid, last-ditch, idea. drain the lube out and tightly fit an airhose somehow - maybe compressed air could push it out? dunno if seals would be damaged? -
Hi, from ID
1 Lucky Texan replied to Silverbullet555's topic in Meet n' Greet. Your USMB Welcome Center
welcome! -
scan for codes. seems like a 'dark current' power drain to me. You could check the current draw, if high, start pulling fuses to try to pin-down the circuit responsible. does it have a replacementradio? check for stuck CD. Does it have an amplifier? make sure it turns off completely - double check any aftermarket electronics.
coil is possible - due to waste spark system, the specific pairs 1&2, and 3&4,share coil halves. Doesn't mean somethingelse might not be going on..... find a youtube video on subaru rear brakes - most newer models have a small drum that has the parking brake shoes, surrounded by the disc part. Your car 'may' be old enough to have drum rear brakes. Someone else will chime in with better info I'm sure.
you don't have to buy from them but, Crutchfield.com has been in aftermarket car audio for decades, see what they have - nowadays, most HUs also have bluetooth.
so jealous.....
The dealer didn't retrieve any codes? coupla things that can be bad without throwing codes; knock sensor and engine temp sensor. Knock sensor can kill power by pulling the advance. Some folks report cheap ebay sensors working well. temp sensor can cause hard starting if NOT reporting a cold engine when cold, or, flooding/'choking' if always reporting a cold engine even when warm. does the car behave better immediately after a battery disconnect ecu 'reset'? If not, I'd expect you're looking for something kinda physical; vacuum leak, low fuel pressure, sticking valve, maybe intermittent ground somewhere,.....?
when I was younger, I either never had a seized piston, or maybe once I paid someone to do that work on an Rambler??? not sure. thanx - are these washers all common sizes then and available over the parts counter? You have said in the past that I was basically driving a ticking time bomb and, pulling that screen for the turbo line, at least(I might skip the valve system ones), seems do-able. what size washer or do I pull it and take it to the parts store to match?
