105
Fitting 14 in wheels
1 Lucky Texan replied to saltytheseadog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
many folks 'upgrade' but, maybe there's an older Subaru model to which you could 'DOWNgrade' to get smaller rotor/caliper combo? -
some odd things can happen from 2 sources; frayed/shorted wires in the body-to-hatch rubber boot. and brake light bulbs or corrosion in the bulb sockets.
- 12 replies
- 2
- battery light
- brake light
(and 1 more)
Tagged with:
figured it's time, 75K miles on originals - 13 years old. so, I got 4 6481 NGK ILFR6B plugs I want to put in, just wondering if there's anything to watch out for and how many of you would use oil or never-seize on the threads. I think NGK recommends dry install. should be similar to our 03 H6es COPs right? I also have an atmospheric temp sensor but dunno where it's mounted, my original has been reading 7 degrees low for years.
Backfires on stock ECU
1 Lucky Texan replied to wyrldtraveler's topic in NA Fuel Injection Engine Tech
our ratings are an average of Resaerch and Molecular. many othe markets use molecular only I think??? someone else may have the specifics better than I do but, my gut says your 91 is appropriate. that said, the ECU DOES get dynamically 'remapped' with data from the knock sensor. There are ways to determine if knock events are occurring and if corrections have been made to the ignition timing. front O2/A:F sensors? Do not use generic or Bosch sensors. OEM or Denso only. Also, I think coolant can 'poison' some sensors so, make sure the car is otherwise in good health - no coolant issues and working PCV valve/system. -
have used Kumho, I like them for a 'value' tire. Had Solus on the Outback, have used ECSTA ASX and 4x (I think) on the WRX. Great grip and good in rain. get a little noisier as they near the end of life. The outback presently has Pirelli Cinturatos and they continue to be awesome - they may have helped save us from disaster thru winter storm Ursa a few years ago coming back from Colorado. complete white-out on a road that closed about 8 cars after we entered. there are plenty of ratings on-line at tirerack and probably discount tire (my favorite tire store). Or go down to your local DT on a midweek-day, have a conversation with them about your driving style, budget.... - ask what tires they have been putting on other Subarus, etc.
strange, never read of this before. are you the only person with access to the car? could a daughter's boyfriend or some other person have been trying to do some maintenance on the car? (I raised 3 daughters. boyfriends are idiots. One left her car's emergency jack and tools at the side of the road.)
never done the repair! - only read about it. If it's the dash temp sensor that's bad, you'd be in 'some' danger not knowing if the engine began overheating. If it's the ECU part of the sensor (if a single sensor, it's a moot distinction as they are in the same housing on newer cars, 2 separate sensore on older cars)) ,the ECU may incorrectly richen or lean the A:F mixture since it will have incorrect data on engine temp.
'01 outback 2.5AT, VDC offroad/ overlanding build
1 Lucky Texan replied to scalman's topic in Off Road
always a new 'weakest link' . have you guys got access to Foresters? stock better angles front and back for off-road. Most impreza aftermarket parts will fit too. -
I like the reviews on Amazon for stuff like this, but it pays to check any 1 or 2 star reviews in the mix. Sometimes there's a 'feature' lacking or something odd I don't like....
