105
looks like someone on ebay is selling singles; https://www.ebay.com/itm/12oz-YIELD-Release-Agent-Penetrating-Lubricant-H2-Loosens-Rust-Instantly-New/123824283059?hash=item1cd4809db3:g:IOsAAOSwxcZc9Fu2
- 105 replies
if at all possible, take it to; http://superiorsoobie.com/
well, even mud and wet streets have 'some' traction....just spitballin' try comparing with and without the FWD fuse in. Compare forward and reverse? maybe get a coupla helpers to video from each side to see what's spinning and what isn't? maybe spring for more ice ? lol! I dunno find a spot to do this without 'high centering' ? ;
cool
I also am in the habit of re-connecting connectors on occasion, in case a fresh 'wipe' of the contact surfaces removes some minor voltage drop. the ecu and all the sensors. solenoids, motors, etc. make the modern car as much an 'outdoor' computer as a vehicle. doesn't mean it will solve the present issue, but is cheap and easy to try.
certainly far from plug and play but, maybe some other small xverse engine could make a fun project? smart car, or honda Fit or motorcycle engine.....? any 3 cyl JDM engines?
to be clear, NO ONE is suggesting shorting the BATTERY terminals in any way. The idea is, disconnect one of the battery cables. Touch that CABLE'S end to the other battery cable's end. yes, you should be cautious doing this as you will still be near the battery , possibly with long metallic tools around, but, it can be done safely.
