105
calipers can bind intermittently, often due to rubber sleeves on the slider - they swell up sometimes. many folks remove them. extremely rare but abd hydraulic hoses have been known to hold pressure. check wheel movement for bad wheel bearing i guess? basically, if the noise is in sync with tire rotation,that tells you which parts to examine. And, if it is noisy at walking speed, pace the car while someone drives slowly to determine which side the problem is on. after a highway run, an infrared thermometer might fine a hot hub - stuck caliper of bad bearing might cause more heat. any wrecks or work done to the car before this began?
I have no help other than to suggest you are not far from Shawn at RetroRoo. Founder of this Forum where we are writing! https://www.retroroo.com/
not as cheap as DIY I'm sure, but user traildogck makes some trans and motor mounts and some other bushings. I think he sells thru ebay. ?? paging @traildogck
- 8 replies
- bushing
- transmission
(and 1 more)
Tagged with:
Daniel Stern may still have a website devoted to auto headlights. I have seen one type of LED aftermarket that had a cone on which the led was 'back firing', seemed to be trying to duplicate a properly oriented line source.....? And, some I think have set screws so you can rotate them to try to create a good cut-off line. Dumping the heat is yet another problem for some folks. There's a little fan or some heatsink - some flexible - that sometimes requires deleting or modifying any rear cover on the light assembly Morimoto or other HID projector upgrades are often considered better than LED.. if any position on the car uses 9005 or 9006 bulbs, there's a 'hack' allowing use of HIR bulbs (Toshiba?) 9011 and 9012 - supposedly about 20% brighter. Just filing a tab down so the bulb will bayonet into the holder. there may be some good youtube video comparisons on this subject.
I think the most common source of P0440 on older soobs is rusted-thru holes in the tank filler neck. have to look behind the plastic usually. But, if the car has always been in Abq, rust seems less likely than something like a cracked evap hose or cracked carbon canister, etc. bad knock sensor will kill power, might lead to knock noise, and often won't throw a code. This is one sensor where a cheap ebay unit has worked well for folks. on the braking....maybe look for loose sway bar endlinks?????
looking for parts brands for my 2014 impreza
1 Lucky Texan replied to RalphtheBRATman's topic in Products for your Subaru
you might check over at www.nasioc.com - those guys really appreciate you doing some searching and reading before you post though. that said, a beefier rear sway bar will not affect ride in a straight line, but will keep the car flatter in turns. easy and not crazy expensive. -
if this is something you only notice when highway passing (above 70mph or so) then yes, try the batt disconnect reset. I ALWAYS do this before a 'road trip' with our 03. It helps with trans 'flare' when passing at high speeds. the tps is how the trans knows a demand for acceleration has been made. some folks have found use of Trans-X to help with slow engagement - but that is not the same as downshifting really.
OK, does it 'seem' like it is in sync with tire rotation speed - or could it be about 4 times faster, that would be ~ driveshaft speed. could you have a helper pace your car with another car , perhaps with a 3rd person as observer, on a 2 lane road such that any bouncing of a wheel might be observed?
yeah, that's why I said 'about' - it has to do with mass ratios plus, typical 'one-driven-axle' cars lose 'about' 13% (IIRC) thru frictional losses but I have read AWD is about 20%...as you said, complicated. his car may be closer to 15-20:1, some higher power cars may be closer to that 9:1 .... I guess someone could measure their accel before a mod like lighter rims, then after - but the numbers would only be good for identical models..... or, take an accel measurement now, then put a coupla 50lb bags of quikcrete in the car, make some new runs and compare. and of course, doens't really 'add' hp, just reduces a 'parasitic' loss of hp. maybe there's a site where values can be plugged in?
reducing mass frees-up a pony or 2 for acceleration. lighter rims, maybe a lightweight crank pulley, if you are always near home and help is easy to get - leave the spare and jack at home. Don't haul around any excess gear. If you literally never have passengers, take the seats out. you can make the car more fun to throw around the corners, cops rarely care how fast you take a legal turn. stiffer springs, fresh struts, maybe stiffer rear sway bar and stickier tires, good brakes, etc. 9-11 pounds weight = about 1hp, 4 pounds rotating mass = about 1hp.
1. See if using the FWD fuse (any size spare fuse in the FWD position in the box under the hood near the strut tower) helps. If it does, you can drive that way indefinitely or until you get a new trans or decide to fix the clutch pack w'ever. Are all 4 tires identical? same brand/model size? they need to be. Has the trans or rear diff been replaced right before this problem began? maybe you have mismatched final drive ratios. 2. The trans will look overfilled of you forget to check the level while idling. It's the only fluid you must check that way.
