105
what car? Assuming it's an EZ30, sitting in the car, the right side bank is cyl #1 at the front of the car, #3 next moving back towards the firewall, and last is number 5' the left side is 2, 4, 6
Bogging in forward gears
1 Lucky Texan replied to Tswami's topic in Old Gen.: 80's GL/DL/XT/Loyales...
broken axle? maybe center diff is stronger in reverse??? -
first, you might want to check here; https://www.subaruoutback.org/forums/121-subaruonlineparts-com/501795-new-lower-pricing-subaru-gear-codes-vip-s.html that's the most recent OEM source I used. Prices were good before the discount. I dunno who is quickest to ship but, I have also used ; fredbeansparts.com, genuinesubaruparts.com and amazon and ebay but I don't know who fulfilled the order.
I think a second set of eyes ,safely, looking at what each front axle is doing could be helpful. Maybe one is broken in the inner 'tripod' joint and spinning some, catching a little, then spinning. Might need to put a piece of tape as a 'flag' on the axle or paint a little dot of liquid paper w'ever to make it easier to spot. If it isn't that, probably the front diff is bad in the trans. There is a magnet on the frt diff drain plug - if it has anything other than 1/8 to maybe 1/4 teaspoon of sludge on it, or worse, 'pieces' of metal, that points to its failure.
hmmm.... you could try the FWD fuse. use any size spare fuse. It's in the box under the hood.... is it still 'clanking' ? have someone walk beside the car and try to determine which end/side of the car is loudest. has the car ever had a trans or rear diff swap? all 4 tires identical brand and model and size?
Brake pad seized on Loyale
1 Lucky Texan replied to Nowah9's topic in Old Gen.: 80's GL/DL/XT/Loyales...
too bad.... -
In another post GD mentioned new castings from Raybestos were a better option than typical rebuilts - dunno if they're available for your car but worth searching for. I think he said RockAuto has them, maybe other sources too? -
just a reminder but, you must check trans fluid level while idling. It will read very high when the engine is stopped. best after a fill to shift into every gear, leave it idling in Parl, pull the stick, wait a minute for the level to drain back down, then check. Also, the volume difference between H and L is only a few ounces, NOT a qt/liter like engine oil stick marks. So, you have to sneak-up on the level.
though it seems to be exceedingly rare, it is possible for hydraulic hoses to fail inside by a layer partly coming loose and making a sorta-'check valve'.
