105
'01 outback 2.5AT, VDC offroad/ overlanding build
1 Lucky Texan replied to scalman's topic in Off Road
if you can not locate a bad bushing, I might suspect brake pads moving back and forth. can someone listen outside the car while you shift it back-and-forth? -
many companies offer stronger end links. I have some Kartboy on my WRX. I would think the type with spherical mounts could work well for you. Perrin has some, probably others. -
duh, I shoulda thought of that yeah, I'm with p'todd - dump the antiroll bars. -
I think I have seen some gadget to do that on an Australian sand rail. ??????
- 20 replies
- differential
- driveshaft
(and 1 more)
Tagged with:
I've read the carrier bearing can really howl when bad.
- 20 replies
- differential
- driveshaft
(and 1 more)
Tagged with:
Batteryology question
1 Lucky Texan replied to Steptoe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
had a 51 chevy with a generator - you REALLY need good grounds for those to be trouble free. (hated the stupid vacuum wipers - terrifiying trying to pass a semi in the rain!!!) -
Felt really stupid just before a road trip once. I was checking the car over before hand; inflating tires, squeezing the window gussets, checking fluid levels - GAH! how did this happen! the transmission is overfilled! I start getting tools out - then, maybe 30 seconds after I panicked I realized the auto trans must be checked while idling. Not Subaru related but once I poured about a qt and a half of fresh oil thru my dad's truck - yep, forgot to put the drain plug back in. So, a few moments later I go to the house, get my parents attention at the back door; "Dad, we're gonna need some more oil. Mom, can you get oil outta this shirt?"
nice!
remove neg battery cable, touch that cable end to the pos battery terminal. reconnect. That should clear the cel - it's possible you first coupla engine starts are odd after doing that until the monitors complete. be very careful around the battery - keep metal tools away from the terminals when you're not using them. if the CEL doesn't clear or comes back, swing by a parts store and have them read the code(s) if you have a smartphone, an inexpensive ELM327 BT adapter and an app like Torque Lite will let you read and clear codes and more.
Today, I changed oil/filter on the WRX, changed gear oil in the 5spd, replaced the lower half of the intake filter box (the slots for the top's 'tabs' have been busted-out for some time, I had zipties holding it together), replaced both radiator/coolant caps. still need to work on clearing the headlight lenses and the a/c system needs o-rings probably and re-charging.
changed oil/filter, inspected around for issues, tightened a few clamps, topped-off coolant and PS fluid (not sure why but it was a little low), tightened stupid RH rearview mirror that is always loose, polished the headlight lenses - will probably re-do the R side - shouldn't have tried to put another coat of the mequiar's UV stuff on it, sorta hazed/orange peeled it. So, made sure not to do that on the LS. I used the turtle wax kit first, #3 and #4 pads, then the rubbing compound. Good kit and certainly seems to have a long shelf-life. I bought it a VERY long time ago. Wife's OBW has been garaged much of its life so, lenses weren't 'horrible'. Examples in limks attached, hope those work. Probably need to change the wiper blades. Still have a misbehaing RS windshield washer nozzle. the car does have some groaning/squeaking noises when maneuvering around, but nothing severe. maybe old bushings somewhere? everything else seemed fine. (Tomorrow, need to tackle some maintenance/repairs on the WRX) https://photos.google.com/photo/AF1Q...w8gqBuBG6rdvSD https://photos.google.com/photo/AF1Q...B72l9PGoKA8R7i
Give me yer honest opinion here boys
1 Lucky Texan replied to sparkyboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
me too but, kinda wonder if the spokers were a different color.....?
