105
I plan to move to yearly changes with both my vehicles. I have no doubt the Shell T6 will be fine at my low usage of the vehicles.
- 169 replies
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
when it squeals (idle it w/hood open, if needed, get a helper to turn the wheel) look in the reservoir for foam/bubbles. The only way that air gets in there is the suction side as mentioned above (quite common to have a bad o-ring) or a bad pump. There's a little investigation going on another forum as to whether debris on the screen inside the reservoir might lead to cavitation. No clear evidence yet. start with mike's suggestion first. If it is determined you need a pump, used is a great option.
Large, unusual models, wagon, Brat
1 Lucky Texan replied to Afloridaman's topic in Historic Subaru Forum: 50's thru 70's
here's a weird question, what are the odds the wood species/source could be determined? might offer a clue as to what continent the wood came from at least. USDA will try to ID up to 3 pieces of wood at no charge it seems, but, the smaller the sample, the more difficult. You may not want to harvest a sample even from the the bottom; -
any markings on it? are the tires plastic, look on them for mold markings -
awesome find. paging @Loyale 2.7 Turbo -
nice! although pricey, rims can really help personalize a car.
my WRX had a bad rear bearing - under 60K miles.
Aisin waterpump is also OK - make sure it comes with a metal gasket, or source the gasket from Subaru. You might look at autoanything and mizumoauto on ebay. you might cross-shopping any OEM stuff by looking here; https://www.subaruoutback.org/forums/121-subaruonlineparts-com/501795-new-lower-pricing-subaru-gear-codes-vip-s.html or, challenge your local dealer to match those prices - it's sometimes better to spend a little xtra if you feel you may need multiple trips back to the dealer vs waiting on shipping or the hassle of returning a wrong part. I had a local dealer match a price on an item, and also get close to a match with a discount on a different item. fyi
ooohhh - good point on the tensioner style. I thought the 'problem' of skipped belts on cars went way back to the late 70s even, - dunno if other makes got any kind of belt 'guard'/'guide or not, but, I have read of typical FWD econoboxes that were towed away to an impound lot having skipped timing when the owner goes to retrieve their car. Of COURSE a good TT driver should confirm the car is in neutral - but do they sometimes forget??? MT, parked, trans in 1st, hooked up to a stinger tow or w'ever, dragged away by tow truck and the tires turn the crank. Or, car gets bumped by some other car.....could also happen if trans in Rev and car bumped from the back I guess. here's one I found on another Forum;
hmmmm, doesn't seem to be fuel-related. you could try some starting fluid as an additional test coupla not-great suggestions; inspect the large tube from the IACV - maybe it's cracked or partly loose. dunno why it would be worse when cold though. clean the throttle body - check into the SeaFoam can with the nozzle. again, maybe gummy when cold....???? inspect spark plug boots for oil/moisture on those cold mornings? how old are the plug wires? is it dew-y on those cold start events? Crank sensors have sometimes been known to fail at warm temps, maybe yours is flaky at low temps?
AC whines periodically
1 Lucky Texan replied to Arthur Digby Sellers's topic in Old Gen.: 80's GL/DL/XT/Loyales...
could it be belt noise?
