105
hello from Latvia
1 Lucky Texan replied to rex_saugerty's topic in Meet n' Greet. Your USMB Welcome Center
Scalman is nextdoor in Lithuania I think @scalman -
Gen 1 replacement fuse panels. PSA
1 Lucky Texan replied to GeneralDisorder's topic in Historic Subaru Forum: 50's thru 70's
just an aside, a guy I work with used to work for Littlefuse. He is sharp! Kinda good to see they can make good stuff. -
what years seem to be affected? any relation to 'low' viscosity oil?
problem is, high output lights have reduced lifespan - that, plus, the xtra vibration of off-road will likely reduce the lifespan so, you'll be replacing them every 3-6 months. Some of them are hotter and might warp/melt the housing too. are any of your bulbs 9005 or 9006? There are some Toshibas, 9011 and 9012 (I THINK, please search) HIR type bulbs that are about 20% brighter - just need a tab cut/filed down to work. or some kind of Morimoto projector upgrade with HIDs ?
hello from Latvia
!!!! wow! -
just check all your fluids and examine the CV boots - particularly the inner one for splits. maybe the rain is washing across some pre-existing oil or grease....? some folks that have had older 4EATs with 'delayed engagement' report very good results from using Trans-X. Often, they add it after doing a coupla drain/fill/drive-a-little procedures before the final darin and fill with the Trans-X only in the final fill.
sometimes, vice grips make things worse because the main force is squeezing tighter in one direction. Worth trying in an emergency of course. those VGs with the 'wr' suffix are very handy to have. they have a flat section, a curved pipe/rod grabbing area, and a wire cutter area - lots of holding and destruction options ! lol
I've never done it so, I'll say probably. There are also 'pancake or waffle' adapters that folks sometimes use under the oil filters - I think when they add gauges inside the car. others will probably have better advice. I know the low pressure switch, for the warning light in the inst. cluster, only comes on at very low pressure - like 4 psi !
First time Subaru owner
1 Lucky Texan replied to RpmTim's topic in Meet n' Greet. Your USMB Welcome Center
cool next time you feel certain the crank time would be too long, try this; switch the key from OFF to ON but avoid START. Switch back to OFF after 4-5 seconds (it's this time the fuel pump runs for 2-3 seconds to assure pressure in the rails) then, immediately cycle to ON, wait, OFF, ON, wait, OFF, START. do the on/off/wait a few seconds quickly in a sequence of 3-4 times, then see if it starts normally. could be something is draining pressure from the rails - leaky injector, fuel hose clamp, pulse damper....
