105
spray them with PB blaster or, brush them with 50:50 ATF/Acetone shaken-mixed-up. Maybe you need some Irwing ez-off type tools if you're saying the nuts are rounded-off ??? https://www.lowes.com/pd/irwin-bolt-grip-5-pack-bolt-extractor-set/1000363541?cm_mmc=shp-_-c-_-prd-_-tah-_-google-_-lia-_-151-_-specialtyhandtools-_-1000363541-_-0&kpid&store_code=2546&k_clickID=go_625706834_34613852470_111132719110_aud-305162224742:pla-260326515041_c_9027195&gclid=CjwKCAiA4t_iBRApEiwAn-vt-5gEdMg02GmRcrnuDwdsi5rhEtzqTkHxoMGTqNrwVBnwE7oLeLeY-BoC6oUQAvD_BwE good luck
timing belt tenisoner uh, 'knock-mimic' wouldn't change with a change in oil viscosity. And, rod knock almost invariable gets worse/more aggressive-sounding with rpm increase. Most folks say piston slap reduces as engine temp gets to operating temp. It also would respond to a oil vis. change I'd think. Piston slap and rod knock would probably both be found in a used oil analysis from Blackstone labs as they increase metals. Tensiioner knock kinda comes and goes and can even quiet-down at some rpms. there is a youtube video showing tensioner knock.
any difference with cold vs warm engine? any smell of fuel under the hood? You can check the charging voltage with a voltmeter. rev a little and it should be around 14 - 14.4 or so I think (others will correct me if I'm wrong) voltage while cranking should probably be about 10 or so. nothing wrong with having the battery and maybe the alt checked at the parts store - but MANY people find typical parts store rebuilt alternators to be very poor risk. If your alt is really bad, a used one from car-part.com or having your original rebuilt locally is a better wat to go. Or check into DBW or Maniac for an alternator. An 08 may have the Mitsubishi planetary starter - they can be noisy/slow to release sometimes but, I haven't read any complaints of 'dragging'. used car lot may be installing very cheap batteries to get cars out-the-door.
don't drive it if it's overheating - headgaskets might be compromised. Check coolant level IN THE RADIATOR until this is resolved. don't rely on the overflow to accurately reflect total coolant volume. could be a bad hose or hose connection - or leaking crimp or cracked plastic on the rad. but sounds to me like you have a good sense of how to proceed. hoping it's an easy fix.
I admit to being ignorant of this type transmission, but, running the odd size pair on one SIDE , or opposite corners, might avoid binding if the rear and front diffs are 'open'. best is 4 IDENTICAL tires; brand, size and model. Also, near each other in wear. Subaru has always claimed the rolling circumference needs to be within 1/4" .
'01 outback 2.5AT, VDC offroad/ overlanding build
1 Lucky Texan replied to scalman's topic in Off Road
I haven't done it though my '03 has very slight clicking at the inner tierod (that ball-and-socket). we can get aftermarket or OEM of course, and parts stores loan the tools. I HAVE read of people using pipe wrenches to swap. but, you need to first fine where the problem is - it seems too loud to be an inner tire rod. I have read of adjustments to the rack itself, dunno much about that. Seems most people just get used racks from junkyards. just depends of the source of the problem. -
grab different parts and try to move them - pin-dowm where the movement is; -
yeah - check all fluid levels and look for a split CV boot. Probably a good idea to confirm cam/crank timing. If it slips a tooth it might still start and run with reduced power. what the smoke smelled like could be a clue - VERY stinky is likely CV grease, sweet-ish toasted marshmallow smell is coolant. Rubber....hmmm, could be a seized timing belt idler ? Or, maybe a delaminated crank pulley....? hard to say without further data
hmmm....seems almost like steering rack bushings issue - seems too loud to be inner tierods...... if you put the front up on jack stands, can you duplicate the problem shifting the wheels front to back (9 o'clock to 3 o'clock) ? Or, grab the tierods and push-pull? (not a bad idea to try lift-rocking them too, bad wheel bearing will allow movement in the 6 o'clock-12 o'clock , should be solid) compare left side to right side. seems too loud to be the little u-joint on the steering shaft but, they can go bad or begin binding. -
I haven't looked for axle numbers but, you could try www.opposedforces.com
weakest link is gonna break. new Subaru axles are very pricey but, maybe a good idea for your usage. a local tuner often uses FEQ heavy-duty axles from World Pac (??? dunno if you can get those) no question about the above advice, many of us regrease and reboot used OEM (green inner cups - made by NTN)
