INTERMITTANT wheel driveline vibration. Heat Related?
1 Lucky Texan replied to uniberp1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes it change if you touch the brakes? with turning L or R ? ever happen at slow enough speed someone could pace the car and listen for the location better? can you feel the vibration? seat-of-the-pants? steering wheel? you might point an infrared thermometer at each corner after a highway run.
Rod Knock 2004 2.5 Forester
1 Lucky Texan replied to Souperoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've never done it so, I'll say probably. There are also 'pancake or waffle' adapters that folks sometimes use under the oil filters - I think when they add gauges inside the car. others will probably have better advice. I know the low pressure switch, for the warning light in the inst. cluster, only comes on at very low pressure - like 4 psi !
Chasing Coolant Steam: Update
make sure you check in the RADIATOR for coolant level until this gets fixed. don't rely on the overflow to reflect coolant volume accurately. it can help to get the nose of the car elevated and boost revs a little after the fans come on, when 'burping' air from it after a coolant refill. good luck
1 Lucky Texan replied to Souperoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you re-work this engine, you might consider an upgrade to the oil pump. particularly if that engine has a 7mm pump, get a 9. If you have a 9mm now, maybe consider a 10 or 11. at 228K miles, I'd bet some bearing clearances have opened a little.
need help asap please car died in driveway leaving for work
don't forget to dig out your English sizes to try too.
First time Subaru owner
cool next time you feel certain the crank time would be too long, try this; switch the key from OFF to ON but avoid START. Switch back to OFF after 4-5 seconds (it's this time the fuel pump runs for 2-3 seconds to assure pressure in the rails) then, immediately cycle to ON, wait, OFF, ON, wait, OFF, START. do the on/off/wait a few seconds quickly in a sequence of 3-4 times, then see if it starts normally. could be something is draining pressure from the rails - leaky injector, fuel hose clamp, pulse damper....
02 outback temp sensor readings
1 Lucky Texan replied to LEOD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsometimes pins get 'pushed-back' inside connector housings.
07 Security Disarm Problems
not certain about the following for an '07 but.... when the alarm is sounding, cycle the key from off-to on 3 times quickly. then, you should try to re-assign the fobs to the car. Pretty sure on an '07 there's still a procedure to do that. check your manual or maybe over at www.cars101.com
spray them with PB blaster or, brush them with 50:50 ATF/Acetone shaken-mixed-up. Maybe you need some Irwing ez-off type tools if you're saying the nuts are rounded-off ??? https://www.lowes.com/pd/irwin-bolt-grip-5-pack-bolt-extractor-set/1000363541?cm_mmc=shp-_-c-_-prd-_-tah-_-google-_-lia-_-151-_-specialtyhandtools-_-1000363541-_-0&kpid&store_code=2546&k_clickID=go_625706834_34613852470_111132719110_aud-305162224742:pla-260326515041_c_9027195&gclid=CjwKCAiA4t_iBRApEiwAn-vt-5gEdMg02GmRcrnuDwdsi5rhEtzqTkHxoMGTqNrwVBnwE7oLeLeY-BoC6oUQAvD_BwE good luck
1 Lucky Texan replied to Souperoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXat 225K miles, why not a used engine? maybe JDM ?
1 Lucky Texan replied to Souperoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtiming belt tenisoner uh, 'knock-mimic' wouldn't change with a change in oil viscosity. And, rod knock almost invariable gets worse/more aggressive-sounding with rpm increase. Most folks say piston slap reduces as engine temp gets to operating temp. It also would respond to a oil vis. change I'd think. Piston slap and rod knock would probably both be found in a used oil analysis from Blackstone labs as they increase metals. Tensiioner knock kinda comes and goes and can even quiet-down at some rpms. there is a youtube video showing tensioner knock.
1 Lucky Texan replied to LEOD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX(edited out bad info) fans may be coming on when the ECU detects open circuit ???
Question about purchasing a subie with a lot of miles.
1 Lucky Texan replied to vikingDBA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfind a local independent mech. that is Subaru friendly - you may need one anyway for a prepurchase inspection. Ask if he has any Subaru-owning customers that might be trading-up soon. but, the older a car is, the less important the brand and the more important the past care and present condition.
Starter motor going?
1 Lucky Texan replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany difference with cold vs warm engine? any smell of fuel under the hood? You can check the charging voltage with a voltmeter. rev a little and it should be around 14 - 14.4 or so I think (others will correct me if I'm wrong) voltage while cranking should probably be about 10 or so. nothing wrong with having the battery and maybe the alt checked at the parts store - but MANY people find typical parts store rebuilt alternators to be very poor risk. If your alt is really bad, a used one from car-part.com or having your original rebuilt locally is a better wat to go. Or check into DBW or Maniac for an alternator. An 08 may have the Mitsubishi planetary starter - they can be noisy/slow to release sometimes but, I haven't read any complaints of 'dragging'. used car lot may be installing very cheap batteries to get cars out-the-door.
MT downshift or pop into neutral and brake
1 Lucky Texan replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat test only works in neutral I 'think' - that's how it works on our Outback, so, was the driveshaft also turning? you might dig around at www.cars101.com to determine if that year-model had rear LSD.
1998 Legacy GT- transmission/ downshifting issues?
1 Lucky Texan replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdon't drive it if it's overheating - headgaskets might be compromised. Check coolant level IN THE RADIATOR until this is resolved. don't rely on the overflow to accurately reflect total coolant volume. could be a bad hose or hose connection - or leaking crimp or cracked plastic on the rad. but sounds to me like you have a good sense of how to proceed. hoping it's an easy fix.
4wd binding
I admit to being ignorant of this type transmission, but, running the odd size pair on one SIDE , or opposite corners, might avoid binding if the rear and front diffs are 'open'. best is 4 IDENTICAL tires; brand, size and model. Also, near each other in wear. Subaru has always claimed the rolling circumference needs to be within 1/4" .
Need Advice to buy
1 Lucky Texan replied to Cam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon an '06, the rear sensor may be more than just a cat conv 'nanny'. best to be prepared for a new cat but, catching up on any lapsed maintenance and examining for exhaust leaks, vacuum leaks and anything else that may throw-off the a:f ratio is important.
Yet another 93 Legacy No Start Story
1 Lucky Texan replied to Wax54's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXclear the codes and see which ones come back after a failed start. slipped timing does seem like a possibility.
2008 Impreza heat fan, AC, defrost not working, AC fuse blows
1 Lucky Texan replied to phillys14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou could try some ohmmeter measurements with the hatch closed, open, ...maybe have a helper push,pull,wiggle the boot.
1 Lucky Texan replied to phillys14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould be a shorted wire in the 'boot' from the body to the hatch.
99 legacy wagon rear diff fit in 04 outback?
1 Lucky Texan replied to LEOD's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdiff bushings fail and could transmit a lot of noise
05 Outback engine in an 06 Forester or 04 outback
is 06 Forry DBW ?
'01 outback 2.5AT, VDC offroad/ overlanding build
I haven't done it though my '03 has very slight clicking at the inner tierod (that ball-and-socket). we can get aftermarket or OEM of course, and parts stores loan the tools. I HAVE read of people using pipe wrenches to swap. but, you need to first fine where the problem is - it seems too loud to be an inner tire rod. I have read of adjustments to the rack itself, dunno much about that. Seems most people just get used racks from junkyards. just depends of the source of the problem.
grab different parts and try to move them - pin-dowm where the movement is;
