Vibration at highway speeds
1 Lucky Texan replied to 1197sts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthose tires may need very experienced eyes on them - they may be old or suffer from tread separation.
EJ25 overheating after rebuild
1 Lucky Texan replied to 98GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas a cross-check, I have seen videos where the exhaust was tested with the block test chemistry. Gives you an idea I guess if the chemical is still good?
High pitched whistle varies with rpm?
I love that movie - almost as much as Once Upon a Time in the West
do OTHER people hear this? could be a tumor. lol!
1 Lucky Texan replied to 98GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh well, aside from intellectual curiosity of bystanders like myself, just getting away from a headache is sometimes the sensible thing to do. honestly, I personally wouldn't have the persistence I see among many folks who post here if I were in their shoes. I mostly just throw out ideas - but, I'm not actually living with the frustration!
1 Lucky Texan replied to 98GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthen if the HG is bad, there must be bubbling of cc gasses coming out of the cooling system when it's overheating - those bubbles 'should' change the color of a block test fluid sample from blue to green/yellow. any bubbles?
you can run the car briefly with the acc belts off. maybe help eliminate one of those bearings as the problem.
1 Lucky Texan replied to 98GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXuntil this issue is fixed, never trust the o'flow bottle level to reflect the actual coolant level in the radiator - rad must be checked separately. Keep o'flow bottle at a normal level. new rad cap might be good to try. several drive cycles could move a few ounces of coolant into the o'flow , over time if the cap or other problem isn't allowing those ounces to be pulled back, it could fill the o'flow.... if 'localized' boiling is the issue, fluid should be pulled back in. If bad headgasket is allowing combustion chamber gasses in the system, fluid may not be pulled back down to normal level in the o'flow. put a coupla small zipties on the o'flow tube at the rad neck, take the o'flow bottle out, clean it by vigorously shaking a handful of ice cubes around in it, replace but cut the bottom of the tube at a 45* angle.
coupla things - de-laminated and slipping crank pulley might make a squeal, but I'd expect stiff steering and maybe low alternator power? intake air filter box not fitted at the bottom where tabs go into slots. but, usually reported as a whooshing sound.
1 Lucky Texan replied to 98GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis coolant pushed out of the overflow when it overheats? is coolant pulled back in when the car cools?
Inline Thermostat Mod
1 Lucky Texan replied to db*****'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcarfreak - thanx for posting that!
Clutch fluid reservoir predictive of clutch wear?
???? weird I have no drips but, I could see that being such a low volume of fluid it may just 'coat' a surface thanx!
Need to lower engine RPM at cold-start idle
CAFE rules have made manufacturers do a lot of things they'd rather not. Warming up the cat conv is one of those things. you're lucky you don'y have air cut valves and a pump like on my WRX - they froze shut in the first 4 years of ownership. I had to use romraider and ecuflash to kill 14 codes to turn off the CEL.
1 Lucky Texan replied to db*****'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can't argue that someone may have created a specific improvement for a specific racing application, just that it isn't common for our daily drivers as far as I have read. I just scanned his article It's more like a personal anecdote than a 'tech document'. - I'm not convinced he understands that a rad cap can maintain over 15 additional psi (over 1 bar) on most of our cars. Also not sure he's using the term 'cavitation' appropriately. plus, in general, you don't want an engine run too cool as it reduces fuel efficiency. an oil cooler could be a better mod but, I dunno. Subaru engineers seem to know there is something odd about the cooling system though - compare an OEM t'stst to a 'typical' aftermarket one. The wax capsule is quite a bit larger - probably needs more hysteresis.
Some of you know I don't get much mileage on my cars, my 06 WRX has about 72K miles - 95% secondary roads so, lots of starts/stops. I have my original clutch, pretty sure the fluid has never been topped off (certainly not by me). So, I was wondering if the volume in the fluid tank getting close to LOW accurately reflects clutch material loss? Or, is is not 'synchronized' very well? Worth getting ahead of the curve or wait until a high gear starts slipping? Is there another way to inspect the clutch material?
Baja payload/vehicle capacity question and traction
on inclines, some vehicles can reverse up better than going forwards. You might experiment with that. plus, using 1st gear may force the 4EAT into more power distributed to the rear. (anyone confirm?)
1 Lucky Texan replied to db*****'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, never read of it across multiple forums/newsgroups for the last 15 years or so. Not saying it hasn't been done, but VERY uncommon I'd say. there is a water circuit involving the heater core that is important, dunno how that would work with T'stat relocation either.
1 Lucky Texan replied to 1197sts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it wasn't doing it before it was parked, I'd suspect a frozen caliper, maybe a failing u-joint, possibly tires if they are getting old. (they are all 4 identical right?)
how to tell which head gasket is bad
1 Lucky Texan replied to whynot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXavoid typical parts store rebuilt alts - if yours is OEM, find a local rebuilder to go thru it - or get an OEM from a junkyard
1 Lucky Texan replied to 1197sts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmove tires in pairs front to back and see if there's a change. (all tires must be identical; same brand/model/size and near each other in wear) there is definitely a LONG list of things that can cause vibration. In a 18 year old car, every bushing is suspect. u-joints can be frozen, inner tie rods bad, brake calipers frozen, struts blown.....
Which transfers more heat - a radiator or long cheap hose?
from what very little I know, subaru scott is on track with putting the unit in a box if possible. there are probably examples/instruction for doing these type of projects on-line. I wouldn't be surprised if some go back to the 70s, but modern materials should be even better. an internet buddy has s imilar device he made for warming a chicken coop/house. His is balanced on some kind of pivot and he uses a wax cylinder (used to vent greenhouses) to 'somewhat' track the sun. It resets the unit to point more easterly overnight to catch the sunrise.
Valve cover gasket leak on 97 2.5
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it's possible a bad PCV valve can contribute to oil loss.
check the Heri hd units I guess; dunno how many models they offer but;
2001 Legacy gas filler tube goes into abyss.
you might clear them and see if they come back. I've had weak batteries set spurious and unrelated codes. Also, P0442 could also be something as simple as loose gas cap or bad seal on gas cap I think.
Complete Dereliction of Sense
1 Lucky Texan replied to unenthuzed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere were 3 lines, 120* apart, on the inner end of the axle shaft. I assumed it was to help align the tripod joint's 'star'. there are some youtube videos that speak about phasing or clocking but, doesn't really resemble our axles. And one site I had seen in the past seems unavailable now it was a page called Killing the Clickers. I couldn't even find it at archive.org probably only important at extreme angles.
