105
Klunk/bumping while driving over 25mph
1 Lucky Texan replied to ClassySoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hmmm....maybe check the axle nut? -
look at youtube for a video or 2? it's pretty easy but, some folks have messed-up the tensioner.... if you can drive something else for a few days, have a local rebuilder fix your OEM alternator, or consider replacing it with a used OEM (car-part.com) or check into a DBW unit or one from https://www.maniacelectricmotors.com/real.html typical units from VatoZone or similar are not well respected and can have short lifespans.
There were older models with CVT too - but I think it required modern fluids and sophisticated electronics to be able to transfer 'significant' power in a unit small and light enough, and with decent reliability, for a motor vehicle. I think the first Justy's were CVT. Using the van Doorne trans? those had less force on them than modern cars I suppose. CVTt has a fairly long history. Benz may have had a European patent in 1886, got a US patent in 1935. Some early motorcycles had stepless trans. Volvo had them , Audi, etc. There may also be systems that use variable volume hydraulic pumps and 'nutating cones' , toroidal systems, planetary gears??? etc. I guess they all have their own set of issues.....
car-part.com , maybe LKQ , their systems already have it figured out and should only show compatible parts. but, if you are shopping craigslist or a pull-a-part yard, take Ido's advice above. There 'may' be a thread at NASIOC with a list of compatible vehicles. I think there were some minor improvements internally on some(?) 2006 and later 5spds if you can find one that's compatible.
vector - do you have grinding noises or just failure to go into gear? does reverse work? these other guys here are excellent mechs, but not being with the car, you need to shre exactly what's going on. if you do decide to swap, you MUST get a trans with the same final drive ratio. There could also be an issue with how the clutch is operated I think?
awesome, be glad to start reading your posts!
you could easily have more than on issue and knock sensors are frequently bad on older soobs. also, cheap ebay knock sensors seem to work fine for people, easy swap too.
