105
did it 'throw' the rod?, any new cam pulleys? any broken teethe on the back of the crank pulley? 3 - 4 cheap/easy ideas; triple check the IACV hose do a tooth count on the timing (you can find the tooth count online, yours 'looks' OK, just a cheap/easy suggestion) I know you said it looked like you had good fuel, but you could try feeding some starter fluid or even propane into the intake when starting, if it gets worse, yeah plenty of fuel, if it gets better - fuel starved? scan again for pending codes?
Help with running issue
1 Lucky Texan replied to Dirtbagsubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
find the tooth count for you engine on line, pull the covers and check timing as mentioned - align the pulley marks and do a tooth count - belt marks will not be aligned. -
I'm not certain I follow everything in you post but, our cars have open differentials in the front and, most, have an open differential at the rear. So, you won't see power at all 4 at the same time. This is not to say there may not be a problem with a broken axle or bad differential, but what you observed seems normal. with all wheels in the air, no parking brake applied and the trans in neutral, if you turn one front wheel, the other side should turn the opposite direction. If the car has a VLSD in the rear, turning a wheel will cause its mate to turn the same direction. If the rear is also an open diff, the other side will turn backwards.
search youtube, probably more than one axle rebooting video - there's even one that shows it being done on the car!
future external coolant weeping might be cured with Subaru Coolant Conditioner.
- 105 replies
I'd give them a chance to fix the issue I think. If there's more to the story than just the flipped tires and you want to avoid PepBoys,, take your car to a Discount Tire. Great folks. They might get a chuckle out of 'one-upping' the competition.
DR rebuild $800 price right?
1 Lucky Texan replied to wagons's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check your front axles. if those trans have magnets on the drain plugs, maybe look for 'chunks' instead of just a little sludge? -
hello from Central NY state
1 Lucky Texan replied to Wrenchbender2.1's topic in Meet n' Greet. Your USMB Welcome Center
I still check the newsgroup occasionally! alt.autos.subaru -
keep all 4 tires identical - same brand/model/size don't let some yahoo confuse fluid drain/fills CONFIRM that the rollers, idlers, tensioner, were changed along with the belt at the last timing belt system service - with parts of japanese manufacture. the schedule is 105 months, or 105K miles, w'ever comes first. -
seems like a good indication someone was really zooming around. Might explain worn-out trans. My 5spd ate 2nd gear at under 70K miles and I have NO power mods.! You should probably consider a clutch fork upgrade too if the clutch is upgraded. If at all possible, get a 6 spd swap. Talk to local tuners/shops about it. www.nasioc.com would be a good place to search/read/ask about options for the car going forward. Heck, someone in this sub-forum , https://forums.nasioc.com/forums/forumdisplay.php?f=21 ,may even recognize the car!
shifter bushings might also be causing a problem. don't use synthetic GL-5 in the trans - many folks report problems. a cheap-ish fluid that some folks like, is the synthetic 'blend' sold at walmart. Subaru's gear oil is good, Motul is good but pricey, Amsoil Severe Gear is good. Any name brand conventional gl-5 should be OK. If you still seem to have problems, drain the oil into a clean container and save it for your replacement trans. check car-part.com or maybe consider a JDM trans.
Smurf Blood! some folks use Redline Lightweight Shockproof, which is green-ish. Others might use a 'cocktail' with 2-3 fluids, one of which is the LW SP. it's good stuff on its own in a manual trans with no pump, or in a diff, but, if it's in a mix, - what with? https://www.redlineoil.com/lightweight-shockproof
