105
shifter bushings might also be causing a problem. don't use synthetic GL-5 in the trans - many folks report problems. a cheap-ish fluid that some folks like, is the synthetic 'blend' sold at walmart. Subaru's gear oil is good, Motul is good but pricey, Amsoil Severe Gear is good. Any name brand conventional gl-5 should be OK. If you still seem to have problems, drain the oil into a clean container and save it for your replacement trans. check car-part.com or maybe consider a JDM trans.
Smurf Blood! some folks use Redline Lightweight Shockproof, which is green-ish. Others might use a 'cocktail' with 2-3 fluids, one of which is the LW SP. it's good stuff on its own in a manual trans with no pump, or in a diff, but, if it's in a mix, - what with? https://www.redlineoil.com/lightweight-shockproof
even if you drill it out from the backside with increasingling larger bits, if you end-up damaging the threads, you can use a thru-bolt with a washer and nut.
- 46 replies
- 1
- knuckle
- snapped bolt
(and 4 more)
Tagged with:
just guessing, did you see the car on the lot? I'm sure if the title can't be found, they can get a replacement. But, sometimes, excuses are made for other reasons. I once had a lot try to scare me off by saying an advertised car wasn't on the lot because it was being repaired. I said, that's cool, when is it gonna be back for a test drive, some other guy came out and said it had a bad headgasket - I said, that might not be show stopper, can you call me when it's available? The first guy said yeah, we'll def. do that. I gave them my number, never got a call. Always wondered if it was some kind of bait and switch thing or what was really going on.
Subaru dealer? in a new thread, you could aask for a shop suggestion near your city - someone may know of a Subaru-friendly independent mechanic. Talk to them about a pre-purchase inspection. Use any serious issues as a reason to either walk away, or get a lower price. At minimum, you waant to drive on-off the freeway after warm-up and watch the temp gauge and maybe look at the overflow bottle for excess fluid or bubbles. Drive in tight circles on dry pavement - should be no grabbing/bucking. Tires need to be IDENTICAL - not just same size - same brand and model too. If they cannot prove unequivocally that a PROPER timing belt system service was done, assume you need to have that done at least.
does the car run normally/better immediately after a battery disconnect reset? bafx with a smartphone and torque app might work for you sometimes, sensors can fail at high temp - crank sensor for instance engine temp sensor might be bad, car runs good cold, but the sensor is always telling the ECU to 'choke' because it's cold - if that has been a problem for a long time, might explain cooked cat converter ??? knock sensor can rob power, but they are usually cracked and bad all the time. getting live data may help find the problem so, hope one of the gurus here can spot an issue in the data.
