105
mine on the WRX were bad at under 70K miles - take 'em off, spin them on a finger. I was shocked at how dry/crunchy mine were. (WRX is only on surface roads and gets driven hard on occasion) if anyone involved in changing struts out is a new to the process, there are a coupla 'gotchas'; the top spring mount has an orientation. There are a 3 holes and the center one faces to the fender. Or there's an arrow or something, it may vary by brand of strut. When you remove a stock assembly , look at the top spring mount. and, there'sia a beveled/cone-shaped spacer that goes on the top of the top spring mount and the narrow side will be pressing on the underside of the strut mount's bearing - don't flip it over or the assembly will 'drag' when turned.
backfiring or very poor running in all conditions could indicate slipped timing I guess. if you get to a point where you want to check, pull the covers, align the marks, find the tooth count for your engine and check for slipped timing. (belt marks are only good for installation.) knock sensors go bad often with no CEL. and will kill power., easy/cheap to replace
95 is probably OBDII, part store should be able to read codes, if possible, ask for 'freezeframe' data too. or consider an OBD app for a smartphone (like Torque) with a cheap ELM327 BT adapter (bafx, veepeak - check Amazon) if missing is confined to one cylinder - swap its plug wire with another cylinder and see if problem follows. OEM plug wires GREATLY preferred if they need changing.
details on car? yeah, many folks have good luck with $10 ebay knock sensors - make note of which direction the cable comes off the old one, remove it, maybe wire-brush the mount are, mount the new one with the cable oriented the same direction. Don't overtorque its bolt. you might check the roll bar mounts and endlinks, also check the rear bushing of the front lower control arm - they could knock/thump. if there is a lot of red dust under the hood and around the a/c compressor's area, it may not be the belt slipping, the clutch may be slipping. Some folks have adjusted their a/c clutches - others have found the a/c relay to be a problem. If the belt seems ok and tensioned properly, try the relay next(maybe swap with a headlight or other identical relay in the box), then perhaps pursue a compressor adjustment or get a used one from car-part.com.
if you hear a click, but there's no cranking, probably need to rebuild the Denso starter's solenoid. The contacts become intermittent. You can get contacts only, or plunger-contact kits and DIY it. Pretty sure there are youtube videos for the process. very common on older cars. Starter may pass a test because it's intermittent. Some folks can have a failed start, whack the starter with a chunk of wood, re-try and start the car.
there is an engine temp sensor - separate function from the temp gauge, though, in soobs after the 90s, it shares the same physical part. Maybe it is holding your car in 'choke' mode? It's located on the coolant crossover I think. Not sure about resistance reading or testing but, it could be bad and not throw a code. maybe you mechanic can test it.
I am unfamilar with models as old as yours - could brake fluid be pooling on top of the fuel tank or inside a crossmember or ????
Thank's Ido, I should keep-up better with this stuff. I bet they paid a lot and now haven't got any relief. Ashmason, you probably have a warranty if this shop has decent reviews and seems legit, take the car back and tell them it isn't fixed. Give them a chance to make it right. But, you may have to bail-out on them if they seem uninterested or incapable of diagnosing the car.
it's a manual? didn't know that was available in Tribeca if so, typical failure symptom for manual's center diff viscous unit is to work OK when stone cold, then grab when warmed-up. a Colorado shop should know this so....I may be wrong. Either get the car up to retroroo in Denver and let Shawn check it out or, one idea, contact user 'traildogck' over at subaruoutback.org - he even does mobile repairs and casts his own line of bushings! Might come down to Pueblo for you....
no sign of brake fluid dripping anywhere? does kinda seem like master cylinder could be at fault - very old car, sitting unused for a long time....add full travel pedal excursions and I could see the MC seals being bad.
a rare condition can occur whereby the bottom of the overflow tube 'seals' itself to the bottom of the o'flow tank. many folks cut the bottom of the tube at a 45* angle. If the tank has debris in the bottom, one way to clean it is with ice cubes, remove it, fit some ice cubes in it and shake them around. make sure the little o'flow tube is clear. The rad cap has a valve 'should' allow one-way flow from the tank back into the radiator - it may be bad which is why we jumped on that first.
If it has only leaked it's fluid and seems otherwise solid, I'd keep driving. I did replace them (sorta twice) on our 03 - if it helps, here's a link to the old thread; (pictures sadly gone - unless there's an image shack hack available for your browser) https://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/48910-lower-control-arm-rear-bushing-transverse-link-replaced-prothane-03-outback.html
- 5 replies
- control arm
- bushing
(and 3 more)
Tagged with:
