1 Lucky Texan
    105
  1. maybe an injector is leaking? just seems like it's behavior is pointing to rich idle. or, IACV is closed too much ?
  2. Tom, ever done an Intergem show or a G&M show hosted by Arlington or FT.Worth G&M clubs? just wondering if I may have seen you at a show.
  3. have you scanned for pending codes? it may be necessary to get live data - ELM327 BT adapters are cheap, and a smartphone with the Torque free app can go a long way towards getting sensor data that 'might' point to a problem. check your brake lights in case there's something weird with the bulbs or corrosion in the sockets - the lights put a drain on the alternator when you hit the brake pedal.....? there a lot of possibles sources for intermittent problems. You might examine ground connections, battery terminals, monitor voltage from the alt. and compare when it's running good vs bad.... youm ight try a battery disconnect reset - if the car has the same symptoms after that, I doubt a:f -related sensors are bad. The ECU is forced to start and run the car using the factory initial settings until data is gathered from the sensors. Could be something more physical; dropped valve, vacuum leak, ...?.
  4. maybe the big hose going from the idla air control valve to under the intake tubing is loose? maybe crank position sensor is getting intermittent?
  5. pd likely means 'pending' - some DTCs won't set a CEL unless they have occurred more than once in some period of time. you may have a bad front sensor or bad wiring to it.
  6. There are used Subarus that are as reliable as other used cars - ANY used car can have major problems. Maybe if you mention your budget, and ask about a Subaru-friendly repair shop near West Hamlin , in a new thread, someone could point you to a good mechanic. Then, go have a coupla conversations; 1. How much and what is the procedure for a pre-purchase inspection if I find an OB for sale? and 2. Do you have any customers that might be looking to sell their OB soon? The older a car is, the less important that brand's reputation is, and the more important the car's prior care and present condition become.
  7. TB in car would be a 'holding back' or bucking/jerking feeling in the 'seat-of-the-pants'. if that Cardan/w'ever joint between the rack and the steering wheel is rusty, it can make 1 or 2 tight spots in the same place in the steering arc in both directions. I do also think many folks have had CV axles present similar issues. maybe especially if the problem seems to be side dependent? (the inside of a turn always stresses CV joints more due to ackerman angle geometry in the linkage)
  8. It isn't clear if you feel binding in the 'car', or in the steering wheel. the little u-joint on the steering column can have a narrow arc of tightness. Spray it with some lube and try it.
  9. +1 one on finding a soob-friendly shop - try to have a pre-purchase inspection done. interference engine. when was the last timing belt SYSTEM serviced and was it done properly? are all 4 tires identical? if not, RUN AWAY.
  10. Throttle Position Sensors can have 'dead spots' in their range of travel - that can cause shifting problems. can you manually shift the trans smoothly?
  11. seems like it would be a good idea to be as clean as possible, or install an aftermarket filter 'downstream'?
  12. ^^^^ good point see if spraying starting fluid will keep it running - then you'd know it's fuel starved
  13. maybe the tube from the idle air control valve fell off the underside of the intake?
  14. well, that quote is 2 things I guess. Inner front CV joint (DOJ or tripod joint) boots often split open and the joint can lose it's lubrication. Known for clunking or popping or other issues on it's way to failure. The front differential has it's own dipstick on the other side from the auto trans' stick. It also needs to be properly filled of course, but, it's drain plug is equipped with a magnet. If there is a reasonable fear the front diff is failing, that magnet may have excessively large particles or an excessive amount of metallic 'sludge' on it.
  15. a steady stream of bubbles might indicate a leaky o-ring on the hose adapter atop the pump or a leak past a suction hose clamp. maybe observe as a helper turns the steering wheel. Very common failure, sometimes causes a whining noise and/or a 'notchy' or 'vibrating' feeling in the steering wheel. A rare bubble or 2 from the splash of the return line is OK. A different type of problem can be caused by a corroded Cardan/u-joint on the steering shaft. It connects the rack to the wheel's part of the column. IT can cause a 'hard' or 'stiff' position when turning the wheel - almost always at the same 'clock' positions in the wheel's perimeter.
  16. It does seem like you could have 2-3 different problems. clunking could be bushings, definitely check the rear bushings on the front lower control arms. steering could be air in the power steering fluid, or maybe slipping belt or even separated craank pulley slipping? I don't think we have that power light but I'm not sure. You are checking trans fluid while idling right? some folks forget as it's the only fluid check like that.
  17. found a couple more instances of the bird symbol discovery; https://www.bangshift.com/forum/forum/bangshift/project-cars-update/the-5-000-bangshift-project-car-challenge/40543-1987-subaru-dual-range/page50
  18. maybe an old Nissan trans or JATCO logo ? Subaru Robin brand? some japanese foundry/casting plant mark? maybe look through here;
  19. try to drain some trans fluid; use a clean drain pan/container, put a quart of water in it, mark or make note of the level, dump and dry it. pull the plug on the trans, put plug back in after you drain a quart (yeah, it will be messy - you could use a transfer pump and suck fluid up the dipstick tube) put in a bottle of Trans-X, check the trans level, if still a little low, you have some fluid in your new clean container you can use to top-off.
  20. knock sensor might be cracked /bad - not uncommon on older soobs and may not set a code. Affects power and can cause the car to tick/knock under load......cheap ebay sensors work for most folks. If the tick is better/gone with high octane fuel, almost certainly the knock sensor is bad. You could also have excess carbon build-up. thud? worn bushings or motor or trans mount maybe....check the bushings at the rear of the front lower control arm especially, lots of force there. check trans fluid level and condition - you must check the level while idling, after moving the shifter thru each gear. Top up 1/2 pint at a time, the marks are NOT 1qt. apart. On older soobs, some folks can cure delayed engagement by using Trans-X, might need some every year or 2. brakes are fairly simple and easy to work on, but there are a LOT of areas where things can need help. Run decent tires, do a good bleed, don't use 'economy' pads, name brand ceramic are probably the best. make sure calipers and other parts are free to move and brackets/bolts are secure, etc.
