105
Cute Fuji logo in casting?
1 Lucky Texan replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
found a couple more instances of the bird symbol discovery; https://www.bangshift.com/forum/forum/bangshift/project-cars-update/the-5-000-bangshift-project-car-challenge/40543-1987-subaru-dual-range/page50 -
maybe an old Nissan trans or JATCO logo ? Subaru Robin brand? some japanese foundry/casting plant mark? maybe look through here; -
try to drain some trans fluid; use a clean drain pan/container, put a quart of water in it, mark or make note of the level, dump and dry it. pull the plug on the trans, put plug back in after you drain a quart (yeah, it will be messy - you could use a transfer pump and suck fluid up the dipstick tube) put in a bottle of Trans-X, check the trans level, if still a little low, you have some fluid in your new clean container you can use to top-off.
knock sensor might be cracked /bad - not uncommon on older soobs and may not set a code. Affects power and can cause the car to tick/knock under load......cheap ebay sensors work for most folks. If the tick is better/gone with high octane fuel, almost certainly the knock sensor is bad. You could also have excess carbon build-up. thud? worn bushings or motor or trans mount maybe....check the bushings at the rear of the front lower control arm especially, lots of force there. check trans fluid level and condition - you must check the level while idling, after moving the shifter thru each gear. Top up 1/2 pint at a time, the marks are NOT 1qt. apart. On older soobs, some folks can cure delayed engagement by using Trans-X, might need some every year or 2. brakes are fairly simple and easy to work on, but there are a LOT of areas where things can need help. Run decent tires, do a good bleed, don't use 'economy' pads, name brand ceramic are probably the best. make sure calipers and other parts are free to move and brackets/bolts are secure, etc.
when I had my WRX at the track the first time, I had an instructor off and on. They were trying to get people to not treat the accelerator like a switch - to roll-on and roll-off appropriately. Once, my instructor praised me "good throttle roll-on!" I didn't tell him I was flooring it just before the apex and he was feeling the turbo spool on the exit!
coupla odd ideas - try fueling with hoses pulled from the charcoal canister - one at a time, might lead to where a blocage is. (Flooded charcoal can or insect/mud nests, sometimes there's a cable going to a solenoid on the can - cable gets lose or is bad, etc.) did you change a front axle? On automatics, you can sometimes feel vibrations when stopped in Drive, if the vibration stops when you slip into N, that can be due to a rebuilt axle.
"Heavy Duty" CV Axles
1 Lucky Texan replied to Jes1991's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Long story short, in a conversation with AWD Tuning, the local shop that repaired my WRX's transmission, they report good success with 'HD' axles made by FEQ , they get them from WorldPac. I have no idea how many models they offer or any other details. -
I think a P0440 is an evap leak? first things to check on an older car; condition of gas cap seal, and inspect filler tube for rusted-thru holes.
- 9 replies
- 1
- dome light
- alarm
(and 2 more)
Tagged with:
Scan the ECU for pending codes. Maybe you could arrange to test drive another new one. Borrow a car or have someone take you to a dealer. If you still feel there's a difference, you may need to demonstrate the difference to a service writer or tech. Otherwise - you may just need to wait until it pops a solid CEL.
system is supposed to give you a coupla stops after an engine stall while driving. I doubt the system is intended to retain a full vacuum overnight (Perhaps a new car CAN, and an older car can't - but it really doesn't NEED to.) as, before driving in the morning vacuum will be re-established quickly after starting the engine. BUT, bleeding brakes with full brake pedal travel has occasionally been reported to compromise master cylinder seals.... dunno if that could match the symptom you have or if you bled the brakes that way......? do you still have the old booster? maybe a test for it could be rigged-up?
if the cat got that hot, it may now be bad. But the cause was likely the misfiring you experienced. too much unburned fuel going into it. can you clear-up the sequence of events for us? I'm guessing you did some work some time ago, then the car had low power/missing, then the cat got red ? or, did the issue with low power happen immediately after some work? what was done JUST before the problem started? I'm confused
you may have 2-3 problems, not impossible with an older car. the brake issue needs to be addressed. The caliper should be able to slide on the pins, rust should not interfere with pad or caliper movement, etc. It's also possible to receive aftermarket parts that are built wrong, or are intended for a different model. "warped' rotors are often due to a panic stop putting a deposit of pad material in one position. If the pads/calipers on one side have been overheating the rotor, a 'bedding in' procedure might help, if it doesn't, you may need a new rotor. the car may have worn inner tie rods or other steering parts/bushings. try swapping rear tires for the front. Good time to inspect, calipers, pads, lug nuts and studs, and wire-brush any flaky rust from rotor surfaces. check the alignment. while a fairly simple system, brakes have a lot of important details and can be a challenge to get into top condition on older or neglected cars. bearings; Subaru bearings can fail with several different symptoms. with the corner or end of the car in the air, rotate the wheel while feeling the spring for roughness - or get a mechanic's stethoscope and listen to the hubs. Also, a bad bearing will sometimes allow the wheel to be lifted/rocked up-and-down in the 12 to 6 o'clock direction. any movement is bad - compare side to side.
