1 Lucky Texan
    105
  1. if there are bubbles after all that turning back and forth , you still have a suction-side leak. could be from a bum rebuilt pump. if you have juddering but no bubbles, you got a bum pump.
  2. I would have thought track punishment/brake heat 'could' have compromised WB grease too. interesting. I have an 06 WRX, I always felt that if I ever had a reason to drop the oil pan I'd get a killerB pick-up. I HATE driving around with a potential time bomb in there!
  3. I have read of this controversy a coupla times in the past - seems to come up every 4-5 years.
  4. over at nasioc, you find folks love the RS enough that they do WRX or STI full swaps into them.
  5. it does seem lke there's a consensus about maybe finding a different shop - start a new thread here asking for a recommendation. maybe someone near your city knows a soob-friendly mechanic. try that over at suabruoutback.org too.
  6. ^^^ def check for leaks. Oil filter adapters, oil pressure sensor, cam/crank seals, etc. if the plugs aren't carbon-ing up and the car runs well - $3000 will buy a lot of oil. but, I can understand wanting to ameliorate the problem. Some folks have used marvel mystery oil or other treatments to free-up the oil control rings. Or, experiment with a high mileage oil or heavier viscosity oil? but, option 2 could get you an engine with half the miles of the present one. LKQ and car-part.com might have some good prices. maybe even try a different shop for the swap?
  7. could this be a bad ECU ? or some pressure sensor in the fuel system?
  8. try a WTB in the classifieds here, and over at subaruoutback.org and ebay of course number on the back of your present fob should be all you need but....maybe others have more info about that
  9. nah, I get it. I have had an unlocked car rifled-thru once, they didn't find anything but a made a mess and the battery ran down.(guess they didn't want the noise of closing the door?) And some prescription sunglasses stolen from a top-down convertible, but I usually don't have anything expensive in the car - I like having the option of parking and locking that car if we're making multiple shopping stops or traveling - but it really doesn't happen that often. the valet mode may be a good fit for you - you could always re-enable the security function if you did park the car with something attractive in it or in a skecthy area. Maybe leave a fob in the car and one at home?
  10. It isn't just about whether a cop is passing by, most burglars aren't gonna want any level of attention - even a passing glance from bystanders. if some hooligans are hanging around the car, you can set-off the 'panic' alarm as you approach it. It's a deterrent, not a guarantee. Even if it went off, then timed out, when you return to the car, it will beep an xtra time and you'd know 'something' set-off the alarm. You could at least check that your lugnuts weren't loosened in an aborted attempt to steal rims or the cat converter hasn't been removed (that happened to a coworker on his SUV !) ((does it have a shock sensor? my car does))
  11. or, contact traildog - he can even do some repairs as a mobile service; http://www.subaruoutback.org/forums/65-parts-accessories-performance/458146-subaru-specialty-products-tdck-cke-ssp.html
  12. seems more likely you had a stuck caliper and the agressive braking may have freed it up.
  13. why do you not want the alarm? have you looked into using valet mode? from; http://www.cars101.com/subaru/keyless.html#2005%20impreza-forester
  14. GD, how are Nissans these days? the ones I've had/maintained in the past seemed to have good iron, but electrical issues.
  15. remans have ALL had a portion or all their case hardening ground away so cheap oversize bearings can be dropped in. not a good recipe for longevity.
  16. checked the crank/cam timing? maybe slipped a tooth knock sensors are known to kill power without setting a code - always worth checking on older soobs. Many folks do fine with cheap ebay replacements. yours may be cracked - usually a bad sign
  17. some aftermarkets may be OK, there is a specific Stant part number that many folks have used. but, typical t'stats are a known problem.
  18. fox - do I recall from the other thread that car runs OK when warm? when the car is bogging down, if you shift to neutral - does the engine rev OK?
  19. knock sensor needs to be inspected - or just swap in a new one. cheap ones seem to work OK for most people in this instance. If original 95, I'm sure it's all cracked and a bad one can kill power.
  20. 1. you should be able to use th key to get in, and cycle the key from off to on 3 times to stop the alarm 2. there is some kind of panic mode that can be triggered if fob buttons are pressed several times in row within a certain time
  21. seems like a lot, I bet there would be some rubbing in the front but, I have noexperience with that. and you'd probably want aftermarket mud/rock guards....
  22. fox - why does the mechanic suspect the cats? what symptoms do you have? car running poorly, CEL or ?
