serotta50
Everything posted by serotta50
Here is my dilemna, 95 legacy lsi wgn, 186k, running great until 1 wk ago. Check engine light comes on solid. Take to reputable independent Subaru shop. Here is what they come up with: pulled codes, p0303 & p0304 misfouire, determined bad ignition coil for cylinder 3&4, replaced coil pack. I pick up the car, drive it 20 minutes and check engine light comes on again, this time flashing then solid. Take back to shop, they determine, possible valve sticking in cyl 3 & 4...would require engine disassembly for further diagnosis. The shop said if I keep driving it I could end up damaging the catalytic converter, which means more $$$$. ANy suggestions appreciated. I have no idea of what this might cost and if it is worth it for year car and mileage. btw, the car is running fine, except the check engine light still on. I want to keep the car, but if fixing is cost prohibitive, then I'll have to get another. Thanks for any input.
I occasionally develop a leak in my sunroof during heavy rains. Checked the drains, they are ok. When I looked at the sunroof today, I saw two things: First, when the sunroof is closed, I can shine a flashlight on the outside/top of the sunroof rear section and see in! There is a tiny bit of room between the rubber and where it is suppposed to seal. Second, when I'm inside and the sunroof is closed, there seems to be quite a bit of play, just up, when I push it up with my hand it travels up maybe an 1/8", then comes back down to normal. This happens in the same spot, rear portion of the sunroof. Other than that, it seems to work fine. Is this normal and can I repair myself?
Just picked up my 95 lsi wgn from shop tonite, timing belt, crank seal, cam seal, water pump, serpentine belt, flush cooling system, and 2 miles from shop the temp gauge starts rising and pegging out at "H". Called AAA to tow it back to shop for mechanic to fix tomorrow. What happened?? Any help would be greatly appreciated.
