botscooby
Everything posted by botscooby
  1. I found this grounded Impreza wagon, GF4 Engine EJ16 1995 Model imported from Japan. The owner says he has been to many garages to try and fix it in vain. The CEL does not come on so I was unable to read the codes. Some technician opened up the ECU and replaced some parts. The engine does not crank and the car has been grounded for two years now. I suspect that since the ECU was tampred with, it needs to be replaced. If its replaced, shall we then be able to read the codes? How much do they cost? Any ideas welcome Thanks Botscooby
  2. My 94 Wagon impreza does not seem to have a low fuel light! Is this on all these models or am I missing something? Botscooby
  3. Thanks Glen. I changed the sensor and the car is fine. The error codes are gone and the start is Okay. Botscooby
  4. My 94 wagon is throwing the following codes 14,15,16,17,21 . I have made an order for the coolant control switch. Does it mean I have to repalce all the injectors also? Also I cant find the loation of that control switch for the coolant temp. Pls help.
  5. I am having exactly this same problem on My 94 Impreza Wagon! I will replace the sensor and see if that improves the situation.
