AWD95
Everything posted by AWD95
ABS Questions
AWD95 replied to a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I pulled the fuse on my 95 using the Haynes manual- I had to amke sure the wheel was straight, put the key in the lock position, disconnect the negative cable, wait a few minutes for the reserve battery chare to drain then pull it(mine was obvious it had a yellow protective cover which was a bugger) All of this to prevent the costly repair of a bag going off-well worth it- Get another manual -
Problem solved! The scanner wasn't reading anything because a fuse "SBK2 or 3" was blown. Which is where my problem was. When I was pressing on the gas my foot touched some wires that touched another electrical connection(yellow) which in turn blew the fuse. FYI- these wires are located directly above the gas pedal(used to solve problems/diagnostics I had checked everything top to bottom, mine vs. new parts, everything and nowhere in any book did it say that this fuse was related to the ignition system but it was in a round about way. So I thank you all but especially Legacy777 for leading me in the right direction and posting a link to endwrench.com(which is where I found the answer in the archives under electrical) ALL YOU GUYS ARE AWESOME!!! Thanks again, check your wires, carry an extra fuse-they're $9.00 from the dealer.
ok did the scanner test.....and nothing.... The autoxray ezread 2000 model scanner says "vehicle is not responding" What does that mean??? I tried 2 different obd2 connectors as well as generic and specific on the scanner and the same result. Is there a special connector?? The scanner says 1996 and later obd2 but mine is 1995 with obd2??
The Car: 95 LegacySW AWD/ABS 5 spd. w/61k Problem: It will turn over but won't start When it happened: I had just started it and it was idling for maybe one or two minutes with headlights on. I just released the e-brake and was pushing in on the clutch and finding reverse(simultaneously)and everything went dead, then the lights came on. So I tried to start it again and it turned over but did not start. 1)I've tested the secondary resistance on the coil pack-ok 2)I've tried to test the ignitor voltage but I don't believe I had the correct LED tester. I just have one with a normal tiny light bulb. 3) I'm getting about 12 volts from the center wire on the connector that goes to the coil pack connector. 4)According to Haynes the primary resistance on the coil pack should be .62-.76 and I'm getting 1.5 Anybody have any probs like this or with the ignitor, ECU, coil pack???? Is there a way to test the ignitor all by itself with a digital meter?? Please help-I'm lost or at least perplexed
2.2 Oil Capacity
Just changed my 95 2.2- takes 4.2 qts. (from the factory book)
